Windshield replace
Staff
It wont. But I had the windshield replaced on my 01 Runner and the windshield shop said it was the same part number as the 91. Go figure. I did a comparison and it looked like it would. That will give you a wider selection in years if correct.
Thanks Terry, the measurement at the bottom of the glass seems to be the same. I was not planning on taking the glass out of my 87 , it just happens the available parts truck is a 87.
Thanks Wyoming, sounds like you had a bad experience there, so the 2000$ was paid for stitches you needed from the glass breaking? Maybe you could expound on that.
Pretty much I got off lucky
The windshield coming out just shattered when it did it put me off balance .
I managed to just nick my elbow well I hit a small vein and it would not quit bleeding
Driving to the hospital was fun
Shop towels and Gorilla tape wrapped around my elbow.
I wonder how some Doctors get through School
Had to get it X-rayed even though glass will not show up.
My luck I get the ER Nurse ready to retire . Just once a Hot cute one that knows her Nursing!!
Rates charged by the Hour it adds up fast .
Next time I will go to the VET instead She is cuter!!
I was surprised that you suggested something as dense as glass would not show up on x-ray, so I had to go look.
http://radiologymasterclass.co.uk/tu...ay_page10.html
Did they have to do anything special to get the bleeding to stop?
Thanks for sharing that Wyoming, I am still in the research stage, I will be sure to tape the window well before pulling it and wear protective clothing.
1 Post
The cheapest way to remove a windshield is with an OLFA utility knife. Use glass cleaner as lube for the blade. Keep light pressure on the glass and the blade should slide through no problem. Getting a corner started is the hardest part. I've removed plenty of glass this way. The glass will flex a bit but remember the knife has to do all the work. Installing glass nicely is an art form. Good luck.
For the cost of a new windshield it is a no brainer let them remove and dispose of the old one.
Install the new one
2 cups of coffee and doughnuts ready to go home.
A nice new windshield no pits .
** To get the bleeding stopped two little stitches of course the kit with the needle and thread was billed at like $250.00
Install the new one
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
