Where to connect that missing tach cable
Here is a picture of where I attached my tachometer cable under the hood on the coil cable cluster. Picture taken from behing the coil. Its the blue connector with the yellow wire coming from the terminal.
I ran a wire from the cluster to the wire shown above. The cluster has a place that you can find in the factory shop manual, that you have to add the wire. I don;t remeber how I knew where to plug it in or where to attach it.
[Coil]
lll <--wires
(0)(0)(0)
(x)(0)(0) <--- connector
l
[firewall]
l
[sr5 cluster]
the x marks the wire that you need to attach the tach wire to. I put a fuse in line, just in case.
[Coil]
lll <--wires
(0)(0)(0)
l
[firewall]
l
[sr5 cluster]
jasonty
41
12-23-2018 01:00 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
Luvmeye22re
08-04-2015 03:53 PM
Esibnitsud
07-30-2015 08:19 PM
altydog
07-28-2015 10:20 AM
