When to Replace Timing Cover?
Old 01-09-2007, 04:45 PM
Bill's Avatar
Apart from obvious damage, are there any reasons or signs that it's time to replace the timing cover on a 2XR series motor?
I'm ready to order parts for my 22RTE, and I'd like to get a new timing cover, cause it would make it just that much more new and shiny. But I've taked to EB and they don't have a turbo specifc cover, so I would have to modify it.
My current cover doesn't look in too bad of shape overall. However it does have grooves mabey 1mm deep from chain rub up the driver side. But With new guides and proper tension this shouldn't be a problem, right?
Old 01-09-2007, 04:57 PM
surf4runner's Avatar
if it leaks replace it. ooOOoo ... shiny
if you modding it, id do it to the 'still good' old one while sourcing a replacement.
Old 01-10-2007, 05:30 AM
Yotaboy's Avatar
I ran mine with groves cut about 3mm into it for about 2 years and had no problem with it. I agree, if its not leaking dont replace it unless you want the bling.
Ichneumon
09-27-2015 04:21 PM
puddlepirate
06-30-2015 05:08 PM
serenity03k64
06-27-2015 07:59 AM
marcusSRG
06-27-2015 07:13 AM
Badger62811
06-26-2015 09:26 PM
Quick Reply: When to Replace Timing Cover?
