What does the box above rear axle do?
Old 09-03-2012, 06:20 PM
ACZR's Avatar
Hello, I need information about the brake system on a 1991 Toyota pick up, the part I am wondering about is on the rear axle the the part that travels from the box, down to the axle. From what I can figure it is some type of adjustment that would aid in braking if a heavier load was being hauled? What I am looking to do is eliminate this and am just trying to find out what parts/knowledge is needed to do the job, if there has already been a decusion on this I do appologize but I was not sure what the correct terminololgy for this was so the search did not yeild anything helpful. Thank you all for your advice.
Old 09-03-2012, 06:22 PM
ThatGuy1295's Avatar
https://www.yotatech.com/forums/f116...emoval-151303/
Here go.
It stands for Load Sensing Proportioning Valve.
Old 09-03-2012, 06:23 PM
TNRabbit's Avatar
It's called the LSPV, or load sensing proportioning valve.
I don't suggest removing it unless you are going to install an adjustable valve.
Old 09-03-2012, 06:27 PM
ACZR's Avatar
Thank you very much for the quick response and the link to the info.
Old 09-04-2012, 04:21 PM
abecedarian's Avatar
LSP-BV (Load Sensing Proportioning Bypass Valve)
It also lets you have your rear brakes if the front's loose functionality.
jerusry
10-19-2015 05:28 PM
gieselman
10-12-2015 01:34 PM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: What does the box above rear axle do?
