Wet air filter stopped running
Old 11-13-2008, 03:31 PM
91Toyota's Avatar
Same day I almost crashed at 60mph because of my stupidity...I decided to go through a puddle of water (bottom of rockers) and got water/mud into my air filter. Unknowingly I went through it again and started driving down the road. And suddenly lost all power and died. I started it and ran it with my foot on the gas...and white smoke came out...feared the worst I took off my air filter and it was soaked...and took off the intake piece and there was foam there. I got all the water out and drove it for the rest of the day fine. Today I had a power surge and my truck acted like it was going to die. I bought a new filter and not sure if it cured the problem.
Is there anything else I should do or change? Thanks!
Oh yeah...just today my truck didn't fully heat up like it should...only went approx 1/2 the way and stuck there...ideas?
Old 11-13-2008, 03:36 PM
kev
kev's Avatar
put more coolant in it. dry air inlet tube insides.
Old 11-13-2008, 04:00 PM
abecedarian's Avatar
make sure the vane in the afm isn't sticking.
and foam in the intake? what filter are you using?
Old 11-13-2008, 05:52 PM
stockyotadriver's Avatar
my truck took a plunge in a very deep mud puddle more like a lake lets say. and the engine died completley submurged. i got it started in the water and backed out of it, while the engine was still gurgling and i couldn't get any rpm's out of her. then drove it home and havn't had a problem, i blew out my air filter tho, im using a cheapo shucks K&N knock off
Old 11-13-2008, 07:26 PM
91Toyota's Avatar
Yeah...it was foamed up...I'm using a wix air filter...no fram for me. I can take a pic of my old filter if you want?
I'll check the vane...thanks!
Thanks...I'll definitely do that.
Old 11-13-2008, 07:27 PM
91Toyota's Avatar
Okay...the surge feels like its when its after start up...no matter how long its been sitting. If its hot or not. It will just feel power less...until like 30 seconds later and it has its normal power.
Charecter1
11-06-2023 10:08 AM
icentropy
07-11-2015 07:21 AM
Jnkml
07-06-2015 01:20 PM
wilbertd
07-06-2015 07:39 AM
karbin
07-05-2015 11:37 PM
Quick Reply: Wet air filter stopped running
