u-bolt flip kit
Old 11-29-2008, 10:33 AM
just a 22re's Avatar
u-bolt flip kit
what is it and what does it do i keep reading that people are doing this and the only thing that comes to my mind is when you do a axle flip you know axle over the leafe and you flip it with u-bolt flip kits and the axle is now under the leafs
if you could post a picture of before and after that would help out alot thank you everyone
Old 11-29-2008, 10:35 AM
Scooby098's Avatar
its sposed to be like a big process right, Hi steer and what not with it. cause I wouldive done it my self execpt I dont wanna go into moving my PS pump
Old 11-29-2008, 10:37 AM
iamsuperbleeder's Avatar
I think it just gains some clearance and will keep the u-bolts from hanging up on things under the truck as well as moving the shock mounts up above the axle, but I dunno honetsly
I too would like to see some before and after pics...
Old 11-29-2008, 10:47 AM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Search Norbert. Be sure to check the classic threads
Old 11-29-2008, 11:16 AM
TOYOTA 1's Avatar
you are correct here are some after, ill see if i have some before shots.
edit.. i cant find any pics of the stock setup. but if you want you can go look under your truck
Old 11-29-2008, 11:22 AM
Mic09dcsm's Avatar
Actually you don't have to do anything to the steering. The pain is you have to weld new shock mounts.
It's hard to see but in this picture you can see where the shock mount and u bolt holder hang down.
And in this one it's smoother so that if you happen to go over a rock too quick it doesn't rip your shocks and or u bolts off leaving you screwed.
pickle6415
04-14-2021 06:20 AM
Adam Edgar
09-20-2015 03:24 AM
sonorn67
09-19-2015 05:39 PM
JookUpVandetti
09-17-2015 09:25 PM
Patrick1976
09-15-2015 11:33 PM
Quick Reply: u-bolt flip kit
