tried every method of bleeding known to man still won't go into to gear
Old 11-03-2014, 05:00 PM
  #41
coderunner's Avatar
Your the man. Sounds like you have a bad master or slave though buddy. Sounds like the internal seal is going out and bypassing causing it to go soft.
Old 11-03-2014, 05:08 PM
  #42
muddmadness's Avatar
Just replaced both slave and master twice
Old 11-03-2014, 05:10 PM
  #43
coderunner's Avatar
Oh jeez. Yeah the only thing I can think of is the backwards pressure bleed I was talking about.
Old 11-03-2014, 05:14 PM
  #44
Weird part is it doesn't do it every time, it is sporadic. I look everyday for a pin leak can't find any it's all dry.
Old 11-04-2014, 10:12 AM
  #45
Anyone know how much gear oil the 89 5 speed manual transmission holds?
Old 11-08-2014, 07:04 PM
  #46
Let me just say "I should have listened sooner with regards to metal fatigue in the clutch pedal bracket "
I took a picture but unfortunately I can't upload it. There was a crack in it the size of the grand canyon. Have a clutch and all the gears again. Have to relearn shifting again it's right on top and not on the floor. I think I pulled a muscle... Lol
Old 11-08-2014, 07:51 PM
  #47
FGZ
FGZ's Avatar
Glad you found the culprit!
Old 11-08-2014, 08:01 PM
  #48
Thank you, I get to sleep again at night. Instead of worrying about how to fix it, it's my only vehicle for the moment and riding the bus totally bites. Lol
Old 11-09-2014, 09:50 AM
  #49
Gevo's Avatar
I was following your struggle.. glad you fixed it.
Old 11-09-2014, 11:14 AM
  #50
Hey Gevo, it's been a few months since we chatted. The truck now has new every thing hydraulic and a new throw out bearing, double reinforced pedal bracket and body mount. Since we spoke last every thing electric and engine related has been running along like a champ. Her pedal issue has been a challenge, but only because I didn't listen and do a closer inspection on the bracket. I just didn't see it until I removed it completely. So good to have her back again.
Old 11-09-2014, 12:22 PM
  #51
Gevo's Avatar
Yeah, I get hard headed about things to.. when people give advice I think "oh, can't be that.." well, foot in my mouth a few times later I've learned to just look at all the advice people give on here... glad to hear everything else is running well!
Old 11-09-2014, 12:31 PM
  #52
Lol.... Right? Guilty as charged, ask for help and then go.. Nope it's not thattttt. Thank you, glad I'm not the only one. Love my Yota.
Old 11-09-2014, 05:51 PM
  #53
Update on shift stuff, second gear was locked out on a corner. It only does it on a corner, what would cause that. Shifts awesome the rest of the time... Weird
Old 11-10-2014, 03:40 AM
  #54
mct75's Avatar
Only thing I can think of is the body is twisting enough to get in the way of the shifter...
Old 11-10-2014, 06:02 AM
  #55
Yep it's my thoughts too, maybe a line crimp or something. It doesn't happen every time either.
Old 11-10-2014, 06:14 AM
  #56
Odin's Avatar
Check to see you have any bad mounts
Old 11-10-2014, 06:20 AM
  #57
Okay I will today after work.
Old 11-10-2014, 07:56 AM
  #58
It is also just in right hand corners and in the downshifts, crazy damn truck.. Lol. But at least she shifts this whole thing makes me want to pull all pedal brackets and reinforce weld to make sure it doesn't happen again. But my luck the floor will give out and I will be Fred flinstoning my way home... Lol
Old 11-14-2014, 09:14 AM
  #59
Update : it's not doing it anymore. I think it's a matter of a bad shifting habit that was necessary before the pedal bracket was fixed. But I will be keeping a close eye on it just to be sure.
Tykiller1994
08-10-2015 07:49 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
94yotaky
07-23-2015 07:50 AM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
sabine
07-18-2015 03:59 PM
Quick Reply: tried every method of bleeding known to man still won't go into to gear
