Touched battery terminals with wrench no power to anythi
Good evening folks,
I acidentally touched the positive and negative battery terminals with a socket wrench on my 91 toyota pickup w/ 22RE while working on cleaning the EGR valve. I had my knee up on the battery while removing some bolts and bumped one of the wrenches I had laid on top of the battery. The socket got really hot and almost became welded to the wrench.
After putting everyhing back together on the EGR, I tried to start my pickup but there is no power to anything.
I pulled out the 80 AMP fusible link in the fuse box under the hood after pretty much destroying the top plastic (finally figured out it comes out from below).
The metal piece on the fusible link was not burned in the middle so I dont't think the fusible link is my problem although I am not certain.
What do you all think may be my problem? Any ideas what to check so I can get back on the road again?
You disconnected the battery and tested it's not damaged? You checked the battery cable and terminals?
The OEM terminal connectors use that top mounted post, if you grounded to the barrel there could be damage in the connection (all half inch of it)
Inspect voltage drop across the other resistors in the relay box.
PS put your battery hold down back on it's a lot harder to short the battery to it's self that way. And find a safety boot for the positive terminal.
Battery is good. I installed it in another vehicle and started just to make sure.
I did have my battery hold down installed, but the OEM red boot had slipped down the positive cable and I didn't notice until it was too late.
How do I check the voltage drop across the relays?
How do I probe the voltage from one side to the other?
How do I use my multimeter to check my grounds. Is it possible one of my ground wires could have messed up after what happened?
check continuity, is what it's called. Which is fancy way of saying "will electricity flow." Think my multimeter it's symbol for ground downward facing arrow. And leads need to be plugged into correct terminals. Touch one lead to neg terminal and start touch body, bare metal and engine block. If both are no continuity then check each ground wire/cable. Check connectors. You can test positive wire but you must disconnect from positive battery terminal or electrical source. To disconnect positive cables disconnect negative 1st. To reconnect: connect positive first then negative.
A continuity test is akin to holding a mirror under an unconscious persons nose , it tells you they are not dead.
A resistance test is akin to taking your blood pressure, it gives a sense of the resting state health.
A voltage test is akin to a stress test(where they put you on a bicycle and monitor your heart and lung function), it tells how healthy you really are and if you can perform the work without collapsing.
For example. A fuse.
continuity says yes it conducts, it doesn't say how well it conducts.
Resistance says it conducts but impedes XYZ much.
Voltage drop testing subjects it to the load it needs to carry. the internal resistance in a healthy fuse will not change, however a damaged fuse when exposed to the load will be unable to carry the work load, as the load increases so does the resistance to the point there is no longer enough current flow.
To check the fusible link, pull either the 80A ALT fuse and/or the 30A AM2 fuse in that black box. One of the tabs on each of these fuse connectors should be hot anytime the battery is connected. If you do not show + battery voltage on these fuse sockets, your fusible link is blown.
See my post above. I think you are confusing the 80A alternator fuse for the fusible link. The fusible link looks like a wire, not a fuse.
Yes, now that I read your post I realize I was confusing them.
So, the fusible link is just the wire going from positive terminal to fuse box?
I unwrapped it last night and the smaller wire nearest terminal appeared to be hanging on by only a few threads so I cut it out and installed a thicker wire.
Does it need to have the smaller gauge wirer nearer the terminal to work properly?
The dealer should have the fusible link in stock.
Yes the fusible link is the wire that goes from the positive battery terminal to the fuse box, but is is not just a regular wire. The fusible link needs to be replaced in its entirety. Do not replace a burned out section of it with a regular wire. The fusible link is the first line of defense for any short circuit in the electrical system. If you attempt to use a regular wire, you risk damaging your entire electrical system or worse, a fire.
Can I pickup the 80 AMP ALT fuse at any parts store or is it a specialty item?
So your 80 amp alternator fuse also blown? I thought it was just the fusible link.
The alternator fuse was not blown, but I messed it up pretty bad last night while trying to remove it. Finally figured out it removes from below. I am pretty upset with myself for not reading up on removal ahead of time.
I am not 100% certain the fusible link was blown. When I unwrapped the positive battery cable last night I didn't see anything burned. All I saw was a thin blue and white smaller gauge wire holding on by a few threads to a thicker all white wire.
It didn't look right so I clipped the smaller blue and white wire since it was only held on by a few threads to the thicker white wire. Can I re-splice the smaller wire I clipped and still have a good fusible link?
I still don't know if this will fix my original problem of no power to anything.
Before you do anything else, do that test.
Now if you spliced together a burned out section of the link, the above test would be invalid.
Do not replace the "smaller wire" with anything other than the same gauge fusible link. It is a safety system and you will endanger yourself, your truck, your passengers and family and other drivers aswell first responders (My family!)
You'll need a new ring terminal, a heavy duty wire clamp, and a roll of "fusible link wire", a section of fiberglass sheathing and a section of self sealing heat shrink.
Anyways...
You can do a voltage drop test without disconnecting anything it is the simplest test, it does require an intact circuit however ie. ground and power, positive probe goes upstream of the item under test negative probe goes to the down stream side. You are looking for a zero or near zero reading on a wire run.
Anyways...
So far as I can tell, "fusible link wire" is just ordinary wire in a tougher insulation designed to contain flame and spark. http://www.whiteproducts.com/fusible-faqs.shtml Commonly, it is 4 wire gauge numbers smaller in diameter (meaning the number is 4 higher) than the wire it is protecting. (If the protected wire is 8 gauge, the fusible link would have 12 gauge wire.)
Fusible links can be purchased already assembled from Toyota (about $30). Just the wire is available from Dorman. http://www.oreillyauto.com/site/c/se...0220/C0172.oap
Of course, you don't want to know what is "commonly" done, you want to know what Toyota did. I can't help you there.
But I wouldn't "cowboy" it by splicing in a big piece of wire. Particularly if you know some of the junction box has been damaged at one time. Try to get the correct part, installed with solid crimps, and bolted up as original.
