Timing Belt Quirk!
Old 01-29-2006, 11:41 PM
4Runner X's 4's Avatar
Timing Belt Quirk!
On a 1994 4Runner 3.0 V6 - I have installed the new belt (a toyota part) and when I turn the engine so the belt makes one revolution, it seems to be off by one tooth. I have reinstalled it twice, making sure it was as tight as possible. The marks line up perfectly on the bottom of the crank and at the top of both cam gears. After it goes around once, the mark on each cam gear and the crank is one tooth over from where it started. I am turning the engine clockwise, the tensioner is in place.
I have done this before and not had any trouble. Does anyone kow what the deal is with this thing?
Old 01-30-2006, 01:09 AM
leebee's Avatar
if you have done everything correctly, the marks will be off a bit more each revolution. the belt does not follow a symetrical path. iirc, you are to turn it clockwise two turns as per the fsm.
lee
Old 01-30-2006, 08:30 AM
eric-the-red's Avatar
Ignore the marks on the belt, they're for initial set up only. Turn the engine 2 full revs and make sure the marks on the actual pulleys are still lined up. Like Lee said the marks on the belt will be off more nad more each turn.
Old 01-31-2006, 07:02 PM
Thanks!
Thanks guys! I appreciate your time and expertise!
Eggslinger
06-08-2019 03:32 PM
thefishguy77
07-30-2015 10:59 AM
nick b
07-11-2015 04:38 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Timing Belt Quirk!
