Is there an Idle Increase solinoid?
Old 09-10-2009, 03:59 AM
DanStew's Avatar
Wondering if the 22re is equipped with some sort of idle increase solinoid when an electrical load is placed on the motor? Just noticing that i will get a bit rougher idle when i have my headlights on in the AM and a noticeable lower idle when i lower the tailgate window but keep my finger on the down button even though it is all the way down.
Old 09-10-2009, 04:58 AM
toyota4x4907's Avatar
No, thats normal for an older yota. Theres an idle up valve if you have AC, but thats about it.
Old 09-10-2009, 09:51 AM
Tubbyfatty's Avatar
You could do the "big 3" upgrade, upgrade your ground and power cables to 4 or 2 gauge.
Do a search, theres a lot of info about it.
Old 09-10-2009, 10:36 AM
Marc's Avatar
Your idle might be too low to begin with.
You could try and adjust it up.
Old 09-10-2009, 11:32 AM
DanStew's Avatar
I got the wires already upgraded. I did up the idle a bit, it was pretty bad at times before, i jsut noticed that when i add power, it goes down, doesnt stall. I actually added a bit of RTV to hold the screw in place since it seemed to be a bit loose. It really jsut seems to be a problem when the engine is warmed up. Drives fine but it had the rough idle. Just curious bout an idle solinoid for that. I knew there was an AC one. But i will keep searching.
Thanks!!
Blamalam
03-12-2022 07:34 AM
Marsheen
02-17-2016 12:29 PM
GrimWolf
08-28-2015 03:36 AM
noosh
08-21-2015 03:49 AM
Sarcazmo
08-15-2015 08:22 PM
Quick Reply: Is there an Idle Increase solinoid?
