stripped head bolt.... reuse gasket?
So im doing a HG on a 22r and when i did the final torque one of the holes in the block decided to let go. my question is after i fix the threads can i reuse the OEM head gasket or do i need to buy another one?
This. Once a gasket compresses and fills in the surface imperfections, it is done. If you release the tension and try to reuse it, it won't be able to properly fill those imperfections. It may seal if you're lucky, but don't take the chance.
John
John
kgcwb44
01-29-2023 10:02 AM
the1998sr5
15
07-14-2020 08:35 PM
