stripped exaughst head bolts
Old 02-27-2008, 09:13 AM
Lifelongtoy's Avatar
Question stripped exaughst head threads
How can I fix these threads? I over torqued while tightening the manifold and stripped the threads. Can I just tap out a bigger hole? Thanks
Old 02-27-2008, 09:50 AM
87toy.'s Avatar
ouch, this happened to me while putting headers on a old vw motor, i helicoiled mine, you could drill it out and then rethread it too thow, shouldent be too hard.
Old 02-27-2008, 10:03 AM
Perfect! Thanks
Old 02-27-2008, 10:14 AM
Matt16's Avatar
Helicoil it. You might have to put in a US size bolt instead of the 10mm shaft diameter (14mm head) bolt that was in there previous. Aluminum is a pleasure to drill into.
Old 02-27-2008, 09:39 PM
Pistonman's Avatar
Napa sells a kit just for 22r exhaust stud threads.
Old 02-27-2008, 09:41 PM
jusfloorit's Avatar
I flipped my stud so the side with the longer thread went in deeper and it worked.
kgcwb44
01-29-2023 10:02 AM
dumpster84
04-30-2016 06:03 AM
09-04-2015 09:27 AM
Dakotaneu
07-27-2015 12:03 AM
whereAreMyPants
07-22-2015 03:32 AM
Quick Reply: stripped exaughst head bolts
