spark plug problems with 3.0 engine.
Old 08-08-2006, 05:06 PM
workinprogress's Avatar
well here it is.i pulled a plug to check and see the condition of it,and when i went to put it back it only went about half way.i backed it out to find that it is cross threading or something.its the right plug,and it went in smoothly up until it stopped a quarter inch from seating.now the hole is stripping out.any ideas on how to fix it,mabey without having to remove the head?
Old 08-08-2006, 05:39 PM
TNRabbit's Avatar
You started it off a thread and didn't realize it until you were well into the threads (cross-threaded). The easiest fix to this is to put a helicoil in.
Old 08-08-2006, 05:55 PM
mr toytech's Avatar
if the treads arent damaged all the way threw then just get the right tap and rethread it. cover the tap w/ some grease so the shavings dont fall into the cylinder. if that dont work then helicoil it. to do that you will still prob. end up removing the head to do it properly.
Old 08-08-2006, 07:24 PM
thanks guys!i thought i was gonna have to take the head off for sure.can you put a helicoil in without taking the head off?
Old 08-08-2006, 07:28 PM
scrid's Avatar
heli-coil
Yeah thay work great too...just take your time...don't rush it.
heres a link to some.
http://www.cyclewareables.com/pages/...heli_coils.htm
Old 08-09-2006, 06:24 AM
got it re-tapped. no problems!thanks again.
Old 08-09-2006, 06:53 AM
Red3.slow's Avatar
samething happened to me. I went to replace my plugs to find one wasn't quite fitting about 30 minutes later a few hundred foul words later I relised it was the wrong size plug.
Charecter1
11-06-2023 10:08 AM
icentropy
09-16-2020 02:47 PM
steve miller
10-10-2015 01:40 AM
crashburnoveride
08-28-2015 09:20 PM
karbin
07-05-2015 11:37 PM
Quick Reply: spark plug problems with 3.0 engine.
