Rune's 3.0 rebuild thread
#61
With the thread on the first page, how do people here break in their engines after a rebuild? I know I've seen it here somewhere, but can't find the appropriate threads right now.
#62
Here was mine after a complete rebuild:
1. 0-100 miles: first oil was standard 10w-30 with easy driving, no engine work over 3000 rpm and no full throttle
2. 101-1000 miles: changed oil to standard 10w-40, still driving easy with no engine work over 4000 rpm and no full throttle
3. 1001-3000 miles: changed oil again with standard 10w-40, gradually increased pressure on engine, occasional full throttle, periodic forays up to 5000 rpm at the end of this period
4. 3001-8000 miles: changed to Mobil 1 synthetic 15w-50, began to drive it like a regular truck (not babying it, not abusing it) with a few hard runs to see if it would stay together! I took a 2,000 mile trip with it during this period. with no problems and average speed of about 75 miles per hour.
#63
My breakin procedure is pretty close to Rabbit's, except I delay the switch to syn for at least 10,000-15,000 miles. Got to give the rings a chance to seat first.
Also, these engines are DESIGNED for low viscosity oils (5w-30). Running 20w-50 and other 'thick' oils will stretch the oil pump housing and result in lower oil pressure. Also 'thicker' oils will cost you MPG.
The death of my last 3.turd was due to some inferior parts too. Hopefully you got rid of them before you finished the build.
Burnt & cracked piston
#64
BTW, the engine overhaul gasket kit from Toyota is pretty sweet. You get more or less everything you need in that one, including headgaskets and the gaskets/washers for the fuel lines. I think the only extra pieces I've had to pick up are the o-ring and gasket/seal for the oil cooler.
#65
hey rune, do the coolant valleys on the head gasket match perfectly with the block? and has anyone ever considered a radiator style engine oil cooler?
I wish you the best of luck
Thanks, Drew
Thanks, Drew
#66
No they don't. The holes were smaller in some places in the head gasket compared to the block.
#69
Ha, this engine was outside on our deck all summer when I was disassembling it. The assembly has been taking part in the, ahem, kitchen. I've kept dirty stuff out of there so it's worked ok, but both I (and my wife) are ready to get it out, something that might very well happen this weekend.
#70
Question for the injector experts here. Why does the FSM tell me specifically NOT to use engine oil on the o-rings when I install the injectors? I think it says to use gasoline or spindle oil, but NOT normal engine oil. Why is that?
#71
#72
Aaargh. The egine is in the egine bay, with the input shaft aligned (I'm pretty sure about this from the relative position of the egine to the transmission), but I can't get them together. I have used the elveler in all kinds of ways, but with no luck. Any more advice from anyone before I contemplate dropping the transmission to get this done?
#73
#76
OEM. Got the flywheel resurfaced for $30 at the machine shop that did my other work and was lucky and got a new clutch, pressure plate, pilot bearing and throwout bearing from someone on craigslist for $100. Hope it works
#79
Rune - To seat the rings, you need to lug the engine some, which creates some extra pressure on the pistons and rings. Accelerate from 20 to 50 in 3rd gear about a dozen times to seat the rings. I second the use of thinner oil. 5-30 or 0w-30 is the way to go for optimum flow, lubrication and cooling.
#80
Well, what can I say.... It runs more or less perfect. No misses, no stuttering, no crazy sounds, no CEL. Timing was just a tad off when I checked it after it warmed up. Makes me kind of scared something big will show up later. But so far it's like it was never taken apart (with the exception of the rod knock of course).
