Reasons for power steering???
Old 10-06-2009, 06:06 PM
GodwinAustin's Avatar
My Power steering belt just snapped and after smelling burnt rubber for a little while, I realized I actually LIKED having to put a little more effort into turns. Weird I know, but is there really any good reason to have power steering besides convenience??
Also, will the engine put out more power since it doesnt have to feed the pump?
Old 10-06-2009, 06:10 PM
BigBluePile's Avatar
well on stock tires, it's probably not that big a deal. When my idler pulley BLEW UP, it really sucked navigating parking lots and such without ps. On the interstate it wasn't even noticeable.
Old 10-06-2009, 06:11 PM
my truck is stock and running on 31s. I am sure it would be a different story on 35s.
Old 10-06-2009, 06:14 PM
jsn_stockard's Avatar
It might give you some trouble on the trails
Old 10-06-2009, 06:23 PM
yeah, I figured on tight stuff it would be kind of tough - but really this truck is more of a DD and really wont see serious crawling type trails often if at all. Plenty of fireroads and moderate trails but I kind of like the idea of fighting the steering wheel a bit. I also feel like there is more feedback from the road without the PS.
Old 10-06-2009, 07:07 PM
82blueyota's Avatar
Cool
i am in the procces of converting my 82 to power steering whats wrong with the cap on the res
Attached Thumbnails Reasons for power steering???-dsc00173.jpg   Reasons for power steering???-dsc00172.jpg
Old 10-06-2009, 07:11 PM
toyota4x4907's Avatar
Nothing. Thats how the founder of Toyota's last name was spelled originally.
Old 10-06-2009, 07:13 PM
sb5walker's Avatar
Lol. Try parallel parking.
The pump robs a bit of power when turning the wheel, but in normal driving, not noticeable.
Old 10-06-2009, 07:17 PM
82blueyota's Avatar
this just struck me as odd every thing else has TOYOTA on it or asin or jet or yakuzi
Old 10-06-2009, 07:24 PM
Theres 2 or 3 other places that say TOYODA on our rigs.
Old 10-06-2009, 10:52 PM
mikelusk1's Avatar
Yeah i found the TOYODA on my steering gearbox and kinda wondered why. now i know!
Old 10-07-2009, 01:52 AM
broyota's Avatar
Toyoda Automatic Loom works
Mine came stock without power steering. It is so base model that it has a carburetor, no power steering, and no A/C
Old 10-07-2009, 01:18 PM
Jay351's Avatar
Just wait till you're parked downhill with your wheels against the curb
Old 10-07-2009, 01:31 PM
The property manager here thinks that without the pump working it might put additional or excessive pressure on other steering components like the box or the tie rod - is this true, or will there be the same amount of wear on the components with or without the pump?
Old 10-07-2009, 01:46 PM
iamsuperbleeder's Avatar
ummm, no, not at all...
but it may put more stress on the steering linkage between the steering wheel and gearbox, depending on how strong you are
there's a leather-like "rag joint" in there that's made to obsorb harsh bumps and jolts so that you don't feel every pebble on the road; that might be the first thing to ware out
Old 10-07-2009, 11:47 PM
red87's Avatar
Totally not worth it to run with manual steering. My truck didn't come with it and parking sucked big time, same thing with three-point turns. I haven't noticed any power or mileage difference since installing power steering on my truck. The only change has been me liking to drive my truck a whole lot more.
Old 10-08-2009, 11:32 AM
ayoung101's Avatar
for me, something is FUBAR'd with my first gear, so i have to physically hold my shifter in first gear from start to finish when i shift into 2nd, otherwise it'll just pop out of gear. while i'm holding it in gear, it works just fine. however, that only leaves 1 hand to steer. and when i blew up my PS pump, it SUCKED HARDCORE to go through parking lots at 1mph around curves with only 1 hand to turn the wheel. it was awful. if i didn't have to hold my shifter in gear and could use both hands, might not be that bad.
Old 10-08-2009, 12:01 PM
516593812's Avatar
I wanna eliminate PS on my 4x4. Can I just buy a shorter belt to do that?
Old 10-08-2009, 12:20 PM
The PS belt on a 22re only drives the PS pump, nothing else. You can just take of the belt and be good to go....
Old 10-08-2009, 12:29 PM
SMOD's Avatar
yeah i had a bad power steering pump when I had 31's and it sucked in parking lots but on the road you can't tell a difference at all really. I'd say fix it if it bugs you. lol. It bugged me really bad becuase of the tight college parking lots.. I had to do a 20 point turn to get out.. now a have 37s and i just back up into peoples cars.
Quick Reply: Reasons for power steering???
