rear end bolt stripped
Old 01-15-2006, 03:30 PM
yotamanbill77's Avatar
I was "killin" time waiting on my new head to arrive so i decided to change all the drivetrain gear oil. I had no trouble with the front differential, tranny, or the transfer case. I then got outback for the rearend and the dang oil filler bolt is already stripped! I could take the drain plug out fine but then i would'nt be able to put oil back in it. I tried a 24 mm. socket and it spun right off. It was already stripped beyond help(not by me). The only thing i know to do is drill and tap it out. Does anyone have a better suggestion? and if tapping is the way to go how in the heck do i make sure there are no shavings inside the unit. thanks in advance.
Old 01-15-2006, 04:09 PM
Nic
Nic's Avatar
From reading other threads here in the past, some have suggested (if my memory hasn't failed me) to weld a socket onto the rounded head. It can then be removed and replaced with another one. I'm sure some will chime in with their bolt horror stories. Fortunately, I haven't had that problem.
If you have to go that route, maybe first you should get a big pair of vise grips and see if you can get it off-since the damage is already done. Maybe its not on there too tight.
Old 01-15-2006, 04:14 PM
waskillywabbit's Avatar
Don't drill and tap it, unnecessary. Either jam a smaller size socket onto it w/ a hammer, try some "stripped bolt remover" sockets (Bob Villa advertises them), or weld something to the stripped bolt head and then use that to get it out.
Old 01-15-2006, 06:45 PM
BeaterToyota's Avatar
Check out the very bottom of this page. That might be what you need.
Old 01-15-2006, 07:37 PM
RustBucket's Avatar
I had the same thing with my bolt. The mechanic said that he put a chisel tangent to the curve of the bolt and struck it with a hammer. The chisel sunk in and allowed the bolt to be turned. Just order a new bolt from the factory (duh)
Old 01-15-2006, 07:46 PM
snap-on's Avatar
in the mean time if you dont want to fight the fill plug, pull the breather, its a smallish hole but big enough for the tip of one of those gear lube pumps that make that job so much easyer.
Old 01-17-2006, 05:11 PM
First i want to thank everybody for the advice. I hamered on a 23mm. socket(one size to small) and it still stripped it off. the head of the bolt is so slim you cant get a good bite on it, then i broke out the pipe wrench and got a good bite on it but the bolt never budged. i cant imagine why anybody would put the filler plug on that tight. i stopped because it was shredding the bolt head, i was wrenching on it with about all i had and i'm no slouch. i never even thought of taking off the vent cap, good idea. i think i'll do that for a quick fix, until i can get someone to weld a socket on it for me since i dont have a welder. thanks again
Old 01-17-2006, 07:06 PM
Nic
Nic's Avatar
As Rustbucket suggested, if you have a good cold chisel and hammer, you might want to try that. I have had to do that with some bolts. It often works, unless maybe it was put on with an impact gun.
Daneums
08-20-2015 05:36 AM
hangtown88toy
07-10-2015 02:33 PM
akaphilly
07-09-2015 02:18 PM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: rear end bolt stripped
