Radiator Fix Thoughts
Just curious if others have tried this-
Is it a good idea to fix a small hole in a radiator with JB Weld?
I don't know that it would work since a radiator tends to expand and contract alot.
Thoughts?
Thoughts?
I tried it on my previous vehicle, I had a small pin hole near the filler neck. It worked for a month or 2 but then started leaking again. After trying it a few more times I just replaced the rad. You may have more success, and JB Weld is cheap enough to try. I just don't think it will work for a permanent fix.
if you decide to try this, keep a gallon of coolant/water in your truck just in case.
jasonty
41
12-23-2018 01:00 PM
Road Bull
10-10-2015 04:55 PM
the1998sr5
07-16-2015 06:20 AM
