Question for this electrical connector..
Old 09-09-2016, 12:17 PM
sam_KOR's Avatar
I was doing intake manifold gasket replacement because of vacuum leak near there. I ended up taking nearly all the electrical connections to get the intake manifold out. Most of the connectors found their home except for this one
Here are some more pictures.
The sensor was broken somewhere Idk where it is.. what it is..
In the wire bundle, it has cold start time switch and RT grounding point. (It's on the left side of the engine when standing towards the car)
(the bottom one is cold start time switch and the one right next to it is that one I'm having trouble with)
Please help!! I want to love my new 4runner again. Cannot wait to fire it up
Old 09-09-2016, 01:12 PM
scope103's Avatar
I don't see the "pigtail" that connects the harness to the knock sensor.
Old 09-09-2016, 03:22 PM
sam_KOR's Avatar
Actually the knock sensor is hooked elsewhere. Thank you though
Here is the video of my engine and what I'm asking. Hopefully this is a better way to ask a question!
Old 09-09-2016, 03:52 PM
scope103's Avatar
The passenger side connector is probably the cold start injector. Are the wires B-W and G?
On the driver's side, I only saw 2 regular injector connectors. Do you have a third? (Those connectors do not tolerate 20 years too well, so you could have a different color injector connector.) Are the wires B-R and W?
And, for me at least, the video is just about the hardest way to tell what you're asking.
What are the colors of the wires to the "mystery" connectors?
Edit: the wire you have connected to the Cold Start Time switch looks like the Cold Start Injector connector (the ferrule is distinctive). The wires to the Cold Start Injector Time Switch are (unfortunately) also B-W and G.
Old 09-09-2016, 04:45 PM
sam_KOR's Avatar
Oh you know what? The cold start switch that I received was a wrong part but fitted perfectly with the cold start injector so that's probably what I was confused about.
So in conclusion, the mystery connector that I was asking in the first place was actually for the cold start switch and the gray connector in the video was for one of the injectors(different color threw me off)
Haha I feel so dumb. but thank you for helping me out!
Old 09-10-2016, 11:52 PM
wyoming9's Avatar
For anyone else it makes it much easier to also be able to see the color of the wires .
Toyota is known for using a few of the same connectors only the wires will tell you most times what it matches with or what sensor
Old 09-11-2016, 11:05 AM
Fossilized
Staff
dropzone's Avatar
any it helps to say what truck it is, IE: 1994 4Runner 3.0
philip64
04-20-2017 04:47 PM
andykrow
09-25-2016 07:42 AM
pursang
07-08-2016 07:40 PM
Steppenwolf
07-07-2016 01:41 PM
taraf
07-05-2016 05:56 PM
Quick Reply: Question for this electrical connector..
