Porche CVs
Porche CVs
Does anybody have any information on these? I heard they would fit on a toyota and are stronger then stock. Is this true?
Thanks
Dustin
Thanks
Dustin
Most of the axles are using Porche 930 CV's and 934 CV's. The only real purpose of them is for CV angle. Basiclly for long travel applications where CV angles are giong to be more so than a stock CV.
Wonder what the advantage over the T100 axles are versus the Porche. I know Porche are stronger, but unless your in the Baja 100 or something, can you break the T100 with the 12" of travel? Im no LT knowing man
Okay.
lol...
To bad your not near me...
I know of a good place you could test it out about 10 min away from me...
Makes me wish the Runners Brakes were working...
Then I would be out there....
Cause tis pouring rain here too!!!
lol...
So does anybody have a price on the Porche 930 CV's and 934 CV's. How hard are they to put in a stock truck? I didn't have time to call Downey, had to work.
Ok, here's a little info.
The T-100 cv's are exactly the same as the IFS cv's. They just have a longer shaft. LT comapnies knew this so, they built thier LT arms to the same length so that we could use a readily avilable part to save on cost. Strength is the same as stock.
Porsche cv's can handle better angle and more power (Stronger). You cannot use stock porsche cvs as the mounting holes will not line up. The ones made for Toyotas are adapted to fit, or I believe in Downey's case use some sort of adapter between them (That's how it sounded to me).
Are they worth getting? Did you break one?
they are expensive, i remember hearing 900 for a pair, but look on ebay too... yes you can break stock axles, when your running a supercharged 3.4 lt truck with stock front t100s threw the desert anything can break.
