P0336 code help
Old 08-01-2016, 05:23 PM
pauldbmx's Avatar
P0336 code help
I'm having this code come on and not sure how long its been on. The CEL has been on since I've owned it.
Symptoms are:
- shuts off only after initial start up (runs for about 10 seconds then dies but if you drive a short distance it wont die)
- when cruising it feels like its missing but accelerates fine.
Parts fixed/replaced:
- replaced the crank position sensor
- replaced the igniter
- fixed a short in the ecu
- replaced the distributor
- new plugs
Any ideas on what could be causing this?
Old 08-01-2016, 07:33 PM
fierohink's Avatar
A worn drift key for your crank pulley allowing it to wander?
Old 08-02-2016, 02:58 PM
pauldbmx's Avatar
That was replaced when I rebuilt the engine 10k ago. Actually what ended up killing the last engine. The crank broke at the key and didn't have any oil pressure, overheated, and no charge from the alternator. Bad day
Vernsyota
03-05-2016 04:59 PM
128keaton
03-01-2016 06:50 PM
your-real-dad
Engine Swaps
02-24-2016 10:44 AM
FinallyOffRoad
02-17-2016 08:39 AM
astein34
08-28-2002 07:31 AM
Quick Reply: P0336 code help
