No spark from coil when hot.
Hey guys, so i got a wierd one for you.
Ive got a 92 4Runner 3vz-e With 216,000 KM's.
Ive been having issues getting it to start when its warmed up and been running for about a half hour or so.
I'm not getting any spark from my ignition coil.... but if i wait 15 mins or so after trying to start it it will start and its never died on me while driving. It started happening randomly about a month ago and not very often but now it happens every time.
Some details: ive swaped out coil and igniter with one from my 94 p/u but that did not solve the issue.
though it might be the pick up coils so swaped distributor with my 94 p/u but that did not solve the issue.
No check engine light on and no codes come up when i check.
thought maybe a loose ground wire but they all attached and clean.
Has anyone come across this before?
Thanks.
Thanks.
Search the forums for this one (use google too). I've seen a half-dozen no-start threads that explain the issue you just described but I can't remember the solution.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
