New Distributor - 22r only advances 5 degrees!
Old 07-16-2012, 09:47 AM
ashamsuddin's Avatar
Found my vacuum advance was bad, so I replaced the distributor (cheaper than just the advance). Have the idle set, disconnect both vacuum lines from the distributor, set timing to zero, reconnect lines, and it only advances to about 5 - and this is with the truck at operating temperature. Shouldn't it advance to 12?
Old 07-16-2012, 09:52 PM
abecedarian's Avatar
Not necessarily.
If you rev the engine up, what does it advance to?
Old 07-17-2012, 10:15 AM
I noticed that when I start it cold, it does advance to 12 degrees. Also, I have the idle set to about 740. When I disconnect the hoses to the distributor (this is at normal operating temp now), the idle drops to about 650. Is this also normal? Or do I set the idle to 700 AFTER I disconnect the vacuum hoses?
Old 07-20-2012, 10:47 AM
slow-mo's Avatar
It will advance up to 12 degrees. There's a range of advancement, not a fixed amount.
Yes, that is normal.
After setting the timming to 0 degrees with the hoses off, reconnect the vacuum hoses and if need be, set your idle speed to Toyota's specification for you transmission type, i.e. automatic or manual.
As to the distributor/vacuum advance only advancing the timing to 5 degrees, check with a hand vacuum pump that the new vacuum advance on the new distributor is holding vacuum. Check both vacuum diaphragms.
Old 07-20-2012, 11:25 AM
Will do, thanks.
Old 07-22-2012, 03:30 PM
4x4jeffyota's Avatar
Sorry for thread jacking but I really have to ask this. When I take the vacuum lines of the advance is there suposed to be suction? Bc I put my fingers on it and I feel nothing. Again, sorry for thread jacking man.
Old 07-23-2012, 01:03 PM
No problem. On mine, at idle you should have vacuum at the port closest to the engine. I believe the other port should get vacuum at higher RPMs.
Old 07-23-2012, 03:08 PM
Alright can I clean it out with anything or is it pretty much toast?
Old 07-23-2012, 09:43 PM
Suction should be coming from the vacuum lines, not the advancer unit. Mine was toast and it was cheaper to replace the whole distributor. If you have no suction coming in on either vacuum line, then you've got other problems.
Blamalam
03-12-2022 07:34 AM
Dennisx2
08-10-2015 06:48 AM
Flossy
08-05-2015 05:14 PM
Dennisx2
08-04-2015 01:26 PM
Quick Reply: New Distributor - 22r only advances 5 degrees!
