My Runner with 33X10.5 BFGs
Old 07-06-2009, 04:05 PM
KVRunner's Avatar
I got my 33X10.5 BFG Mud Terrains mounted a couple of weeks ago and I just got the time to wash it and snap a couple of pics. It looks a lot better than it did on 28s.
Old 07-06-2009, 04:16 PM
90_2DOOR's Avatar
Looks sick man, did u try flexing it yet? just curious on the rub, if there is any.
BJ spacers up front and Land Cruiser Coils in the rear and it will be perfect! and it will fix the rear sag.
Old 07-06-2009, 04:27 PM
TACO626's Avatar
Looks fresh!
KVRunner's Avatar
The sag is not near as bad as most that I have seen. As far as rubbing. None what so ever. I used a floor jack to stuff each tire and they arent even close.
Old 07-06-2009, 04:29 PM
Tubbyfatty's Avatar
Wow, looks great! I think that might be my next tire size when these 30s wear out.
Old 07-06-2009, 04:49 PM
Justinlhc's Avatar
That factory offset is amazing. My 32's rub pretty bad, but I have a 4"offset and 11.50's. I also have 1.5" BJ spacers so I thought I was safe in the front.....
Old 07-06-2009, 04:50 PM
drmix's Avatar
I wish my rear sag was as good as yours! I need to get mine lifted soon.
Are those aftermarket decals on the lower part? I havent seen any like it before
Old 07-06-2009, 04:53 PM
toyota4x4907's Avatar
I need some 33x10.5s. 31s with 2"bl doesn't look too good anymore.
Old 07-06-2009, 04:58 PM
KVRunner's Avatar
Those are factory decals on the lower section. It had some sort of appearance package option as it appears on the window sticker.
Old 07-17-2009, 01:25 PM
lukeland68w's Avatar
KV, nice runner. Im thinking of putting my 33's on my sr5 rims but im unsure of the rubbing. I have a runner like yours w/ no lift but im sure it will rub if i put on the 33's.....could you show some flex shots or maybe some shots with the steering fully turned. thanks.
Old 07-17-2009, 04:30 PM
Jay351's Avatar
It has been proven time and time again that on STOCK rims 33x10.50" tires will NOT rub. The wider or farther out the tire sticks the worse your clearance gets..
Old 07-17-2009, 04:40 PM
desertcamper67's Avatar
Looks good. Hows the power with the new meats?
Old 07-17-2009, 04:55 PM
89silverpu's Avatar
Yeah untilll you take it offroad....
Old 07-17-2009, 05:00 PM
RMA
RMA's Avatar
Or the first time you turn up into your driveway with them ...
Old 07-17-2009, 05:02 PM
89silverpu's Avatar
haha that too
Nothin a little trimming here and there and a little pounding here and there won't fix I don't have any rub anymore
Old 07-17-2009, 05:14 PM
Jay351's Avatar
BFH my friend, works almost everytime
Old 07-17-2009, 05:16 PM
89silverpu's Avatar
Not on the rear fenders...cutoff wheel required
Old 07-17-2009, 05:50 PM
Jay351's Avatar
Thats lame. My rears dont rub at all
Old 07-17-2009, 06:01 PM
89silverpu's Avatar
You've also got a lift and idk if you wheel in rocks, your tires get stuffed up real good when wheelin rocks and steep ravines, they didn't rub till I got really stuffed.
Old 07-17-2009, 07:08 PM
KVRunner's Avatar
I have no lift and with the tires stuffed all the way in the front or at full lock, their is no rub. No rub in the back either, not even off road.
Quick Reply: My Runner with 33X10.5 BFGs
