Mustang Seats in 93 Pick-Up
#26
So to the OP, is that 40/60 split bench a direct bolt in for a non-lean back bench in my 93 reg cab? Cause if its in good shape and the bottom cushion still "cushiony" I might take it off your hands.
#28
update: this weekend, i'm working on getting the second seat in. it's more tricky than the last. i made a bar that goes along the back with two bolts welded up. in the front of the seat, only one hole lines up. so i'm making a small bracket for the other side. the tracks mount to the seat in the exact same way the driver's seat does. i'm even going to re-install the driver's side slide adjustment lever, as it's loose now.
and before someone says: "pics?"--- i'll have them up tomorrow or monday
#29
time for pics:
getting the rails to fit the seat is the same as the driver's side: tap the furthest back holes and elongate the track holes slightly. then extend the adjustment lever. (i re-mounted the driver's side because it was loose. it's the uglier of the 2 welds)
slight bending of the cross-piece
and the modified adjustment levers
ready to paint
now for the brackets i used
the one hole that lines up. it's the highest, so i had to use it as the start point to use as few brackets as possible
aaand paint (self-etching black)
trimmed bolts
and now to install
ta-da!
and i tried moving the driver's seat, but it sat diagonal and lop-sided, so i just painted those brackets, too
ready to paint
trimmed bolts
and now to install
ta-da!
#38
hair over a hundred. the guy i bought them from wanted 150 for the front and rear, but i talked him into just the fronts
i don't know if these will work too well with a single cab, but if someone wants to come over, it'll take 5 minutes to swap the seats and find out. i'm about 6'2" and these seats are comfy. i've fallen asleep easily (never while driving). love 'em.
#39
Looking nice, man! Wow, that's a good looking interior.... Love the Shifter Set up(w/out the console section like my 4Runner has).... it looks CLEAN!
Seat covers are nice, enjoy!
PS> I keep hearing that 90-95 4Runner seats bolt RIGHT IN on my rig.... Even found a thread. Just trips me out, as I've measured the bolt holes twice and could have SWORN it was different! lol.
#40
1 Post
Those seats look fantastic man, i've got to ask though, what model mustang were those out of? I've been looking for three months for a set and still haven't found them. I'm starting to get that itch to finish the truck since i got new front fenders.
