Jumper Wire for A/C Recharge with R12?
Old 07-12-2006, 01:16 PM
GunManOsh's Avatar
Before I got this 93 pickup I had a Ford Probe that used R12 for A/C refrigerant as well. To recharge on that vehicle you just had to hook up a hose to the low pressure side of the system and unplug a connector which controlled when the compressor kicked on and off. Once you had the connector loose you would use a short jumper wire to trick the system into running and it would pull all the R12 it needed out of the bottle. I have a bunch of R12 cans that I got from my wife's grandmother so that isn't an issue. And I have the hose to hook up to the bottle. I just don't know if I need to use a jumper wire on the Toyota truck like I did on the Ford Probe.
Who's done it?
MO transplant
04-23-2023 11:58 AM
nanhodges2733
05-29-2020 03:28 PM
stock87yota
07-31-2015 10:08 AM
jackiebrownia
07-20-2015 09:02 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: Jumper Wire for A/C Recharge with R12?
