intermittent hum from right front wheel
Old 01-28-2014, 07:56 PM
michaelh's Avatar
'90 stock 4runner 4wd 250,000 with relatively new tires. Very intermittent noise that sounds like driving over pavement noise grooves. Occurs at varying speeds and lasts a few seconds to no more than a minute at a time. Hitting a bump makes it stop although that is not necessary. Does not impact handling. Might occur several times a day or not at all. I really appreciate the expertise here. The more info the better.
Old 01-28-2014, 08:46 PM
Kingjerd's Avatar
With new tires, it may be variations in the road making contact with different areas of the corner blocks of the tires. What style of tire is it? If its a more aggressive tire for off road, this will occur more often.
Old 01-29-2014, 10:19 AM
michaelh's Avatar
thanks for the respone Kingjerd. Doesn't seem like a tire issue - the volume of the noise is the same regardless of speed/road type and it stops if I hit a small bump or even on its own after a few seconds. Would a wheel bearing going bad cause something like this?
Flying91
45
04-11-2024 04:39 PM
PlayAwhile
07-20-2015 11:36 AM
1994toyota
07-17-2015 03:03 AM
skoti89
07-06-2015 07:45 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: intermittent hum from right front wheel
