Infinite radiator air bubbles
Old 04-03-2011, 10:49 AM
Slowtech4R's Avatar
Just trying to confirm my suspicions.....The 3.0 in my 207K 94Runner is the second motor, and has about 110K on it. Recent timing belt/water pump and truck runs great. I've had/have a small amount of whiteish smoke at startup for a year now and while bleeding rad. on an incline it seems that the air just keeps coming while squeezing the upper rad. hose. Should I assume a HG leak into a cylinder or look for a non-obvious leak somewhere. It doesn't seem to need much coolant over time, but will top off rad. occasionally(three weeks or so)Does anyone remember the post concerning checking the A/F for exhaust gas? can't seem to locate this post. Thanks for any response to this tiring subject.
Also, possibly related, noticed significant gunk at the oil cooler, just one of the many leaks areas on the old rig. What are the common problems in this area besides new seals/gaskets. Is this a common place for A/F to disappear? Thanks
Old 04-03-2011, 10:59 AM
874runnersr5's Avatar
hg most likely is done, get a coolant tester kit that tests for combustion gas.
Blamalam
03-12-2022 07:34 AM
the1998sr5
15
07-14-2020 08:35 PM
09-04-2015 09:27 AM
Logz808
07-26-2015 07:09 AM
Avenged
07-09-2015 07:55 AM
Quick Reply: Infinite radiator air bubbles
