I ruined a fusible-link. I could kick myself...
Old 10-18-2010, 01:17 PM
barthmonster's Avatar
91 4runner with a non-functional chargins system and a constant battery drain. Was doing some troubleshooting with a VOM and measuring each circuit with fuse / fusible-link removed. When I tried to pull the 80A fusible-link (fuse?) it wouldn't come out. Then the plastic broke. I tried to grab what was left of the plastic and it broke, then the guts of the thing broke... Starting to worry here, can I remove the whole fuse block to work on this ??
Thanks for sharing your knowledge gentlemen, I feel pretty stupid for doing this...
http://picasaweb.google.com/67Polara/Misc#
Old 10-18-2010, 01:20 PM
also where would I buy a new one, dealer only or ?? Thanks again...
Old 10-18-2010, 01:22 PM
2DoorRunner's Avatar
.......Nevermind i was thinking fuse box and not fuse
Old 10-18-2010, 01:30 PM
I'm hoping at this point that by removing the fuse-box from the firewall there's a way to push this fuse out from the back after disconnecting the wires (for that fuse only) from the back of the fuse box... anyone know...
Old 10-18-2010, 01:47 PM
Randyman...'s Avatar
The 80Amp Fuse's wires are BOLTED to the leads in my 87 4Runner. IIRC anything above 30 amps will use bolts to attach the wires and won't be simple "blade" type slide in Fuses...
Old 10-18-2010, 02:15 PM
thanks, I finally found that in a search... Dealer only item I'm guessing...
mine is trash...
Old 10-18-2010, 02:21 PM
O'Reily's et all should have them IIRC...
Old 10-18-2010, 02:45 PM
xXbrutalXcoreXx's Avatar
Yeah you can get them at checker or autozone. I blew an 80A fusible link a couple months ago and was able to get 2 of them for only a couple of bucks.
Old 10-19-2010, 04:40 AM
TNRabbit's Avatar
Don't feel bad; a TON of us have been fooled by (& broken) that 80 amp fusible link. I paid $45 from the dealer for mine~ DOH!
Old 10-19-2010, 05:54 AM
richf's Avatar
hahaha it happens to alot of people. Mine was already blown when I tried to replace it. I used some needle nose pliers and destroyed it. I paid $15 at the dealer thinking it was some hard to find fuse and then I saw them at advance auto parts for $3.
Old 01-13-2011, 01:55 PM
ChaseSS4R's Avatar
Wait... So how do you remove it?? lol I broke the top off of my 80A Alt Fusable link so now all I have is the little prongs sticking out of the fuse box..
Old 01-13-2011, 01:58 PM
camo31_10.50's Avatar
look around under neath the fuse box, it's BOLTED in there..
Old 01-13-2011, 02:00 PM
ChaseSS4R's Avatar
lol awesome...
Old 01-13-2011, 03:17 PM
Zelephant's Avatar
Haha, yup, the fusible link got me too! Luckily I checked Autozone and got one for $3.
Old 01-13-2011, 03:37 PM
myyota's Avatar
You can use a screw driver to unclip the 80 amp fuse holder and slide it out the bottom of the fuse box. There is no need to unbolt the fuse box. You can get a new fuse at the parts store for under 10.00 dollars.
Old 01-13-2011, 04:01 PM
peckinpah's Avatar
Push the plastic clip over, then press down on the broken fuse. The fusible link assembly comes out the bottom of the fuse box. Then you can unbolt the fuse itself and replace that. I paid about 2 dollars for my 80 amp fuse at Kragen. They have them with all the other fuses in the fuse department.
The fusible link is nothing more than a piece of plastic that the wires from the alternator bolt to that hold the fuse in place. I don't see how you could destroy that.
FWIW, I did the same thing (destroyed my 80 amp fuse trying to pull it out). HTF are we supposed to know that the assembly comes out the bottom of the fuse box?
runnygirl19
11-19-2015 11:39 PM
rmill05
09-27-2015 01:43 PM
JamesDINAN
09-22-2015 05:37 AM
runnermedic
13
09-21-2015 05:20 PM
Gone Fission
09-08-2015 04:24 PM
Quick Reply: I ruined a fusible-link. I could kick myself...
