I need a quick answer! 5spd and auto speedometer cable
Old 09-07-2011, 02:58 PM
thisgsx's Avatar
stupid question, but are they interchangeable? i've got a 5spd, will one from an auto fit/work?
Old 09-07-2011, 03:31 PM
Hadmatt54's Avatar
Give us some details...What year and model of vehicle is the 5 spd in? What is the auto out of? Long wheel base, short wheel base, 2wd or 4wd, etc.
Old 09-07-2011, 03:35 PM
thisgsx's Avatar
both vehicles are '90 3.0 4x4 4dr sr5, mine is 5spd, the one from the junkyard is an auto.
Old 09-07-2011, 05:19 PM
Hadmatt54's Avatar
Both vehicles list the same part # for the speedometer cable...
should be the same!
Old 09-07-2011, 05:21 PM
thisgsx's Avatar
ok, thanks!
Old 09-08-2011, 07:18 AM
BigSwole's Avatar
Go to napa. Its 20$. And a warranty and you don't have to pull it!
Old 09-08-2011, 08:11 AM
Numbchux's Avatar
The one from my '87 a340H threaded right into the tcase that was behind a '86 W56. The port for the speedo is about 4" further back in the truck than the 5MT, so if they're different, is probably just that the one for the auto is longer.
Should work just fine.
Old 09-08-2011, 02:07 PM
thisgsx's Avatar
the one for napa doesn't fit so i had to return it.
anyways, i went to the junk yard to pick up the speedometer cable, and it fits.
Old 09-08-2011, 02:13 PM
BMcEL's Avatar
Napa told me it was a dealer only part.
I got mine from Toyota for $115 a few years back and they didn't ask if it was for an automatic or manual.
Old 09-08-2011, 02:25 PM
thisgsx's Avatar
I am pretty sure they were trying to pull a quick one on you. The length of the cable itself isn't the problem. The problem with the Napa cable are the fittings on both ends of the cable. The end that plugs behind the cluster is smaller than the OEM, therefore it doesn't fit. As for the end that plugs into the VSS, the cable that is protruding out has a ridge that is thicker than the OEM, therefore, that doesn't fit as well.
Old 09-08-2011, 02:35 PM
BMcEL's Avatar
By directing me to Toyota? I think they pulled a quick one on you by selling you the wrong part lol.
Old 09-08-2011, 02:49 PM
thisgsx's Avatar
I meant Napa, hence it was bolded out.
Old 09-08-2011, 02:58 PM
BMcEL's Avatar
Me too...I was saying Napa probably did the right thing by directing me to Toyota since Napa doesn't have the right cable.
Old 09-08-2011, 03:02 PM
thisgsx's Avatar
ya my mistake. lol
Old 09-08-2011, 03:23 PM
BMcEL's Avatar
Liadrin
04-25-2022 02:54 PM
jasonty
41
12-23-2018 01:00 PM
mr_manny
07-31-2015 10:39 AM
altydog
07-28-2015 10:20 AM
Michael oaks
07-27-2015 11:47 AM
Quick Reply: I need a quick answer! 5spd and auto speedometer cable
