I may have ruined my throttle body?
#81
mt_goat.........thanks for chiming in and I appreciate it...
I did get the correct mount......http://shop.advanceautoparts.com/pro...ype=38&PTSet=A..... however I didn't take the rear drive shaft off when I dropped the tranny cross member.
should I have dropped the rear drive shaft? then removed the cross member?.....I can tell you this that the cross member was much easier to remove than it was to install!...
I just thought the rear drive shaft was not in the way so I left it attached.....now for the front propeller shaft I haven't removed it yet to install the bottom 14mm bolt so I'm going out to do that in a few minutes....
#82
I still have a problem with my tranny woul you be so kind to read this thread and give me some feed back on my transmission problem
https://www.yotatech.com/forums/f116...ong-po-164870/
Blamalam
03-12-2022 07:34 AM
Blamalam
08-16-2015 12:29 PM
