How to kill the evil buzzer but save the dome light?
Old 02-25-2006, 06:46 PM
dirtykaw's Avatar
So I unplugged the stupid BZZZZZZZZZZZZZZZZZZ seat belt idiot warning-sound making box underneath the dash (by the brake pedal) on my new truck, an 89 4runner with a 22re, and thought I was a real genius.
Then I discovered that the dome light was wired through it. Ouch.
Does anyone happen to know which wires I should cut? Or have a better idea? I can't get the box out of there for a closer look, it seems to be riveted.
Old 02-25-2006, 07:09 PM
87rustbucket's Avatar
take the buzzer unit apart and bend the two little metal tabs apart or just remove em!
Old 02-25-2006, 07:30 PM
marko3xl3's Avatar
Can't you just connect two of the wires on the connector together to make the dome light work?
Old 02-25-2006, 09:24 PM
lftd_86_yota's Avatar
you shouldn't have done that!! the buzzer is sooooooothing. it's a toyota signature.
Old 02-25-2006, 10:29 PM
getitdone's Avatar
I just stuck a piece of paper in between the metal tabs. So much better.
Old 02-26-2006, 04:47 AM
jjenks0's Avatar
Is that the same buzzer that tells you that the key is in the ignition?
Jack
Old 02-26-2006, 07:23 AM
dirtykaw's Avatar
Yeah.. as I say, I can't take the box out without breaking something. Its got about 10 wires going in there. Maybe I willl just have to break the tab and duck tape it back togather.
Old 02-26-2006, 07:33 AM
getitdone's Avatar
I think it is on a tab that you have to pull the box down to get it off. Does that make sence?
Old 02-26-2006, 05:36 PM
Bobakazi's Avatar
Does it buzz after you take the key out of the ignition and open the door? Just poke the key hole hard with you finger. It should go off. I have to do that every other time I get out. No biggy.
Old 02-27-2006, 05:03 AM
jjenks0's Avatar
No jsut when it is in the ignition
theking11863
03-19-2016 09:36 PM
AkitaDog
09-01-2015 08:05 AM
mr_manny
07-31-2015 10:39 AM
TDonkey
07-26-2015 10:14 AM
icentropy
07-14-2015 10:23 AM
Quick Reply: How to kill the evil buzzer but save the dome light?
