How do you know a motor mount is broken?
LMAO! And it's his girl who is home now who's gonna go out and work on the diagnosis. (If I dent the oil pan though I'll be looking for a new home)
#25
That's the one thing that sucks about being a chick. Lack of upper body strength. If only I could turn a screw driver with my thighs I'd be all set! (Don't get any ideas guys!!)
#26
If ya dont coat those bud built bolts with anti-seize they may never come out!
#27
I just can't get enough strength to push up while turning counter clockwise. Plus I am favoring a finger I cut really bad on Monday (I probably should have had stiches)
I feel stipud that I can't get em out but all I am doing is starting to strip them...
#28
We've had em out 5X this past month! Seriously if I could cuss here I would. I am pissed. Can't get the danged things out. He doesn't have the hex screws in there any more. Giant flat head screws that go into the sonoran steel x-member. I know they come out. He seems to have no problem and I have never had to take these out.
NO! dont strip them....try putting a jack under the crossmember to relieve all the weight on the bolts....they should come out a lot easier
#29
Yup already did that. Come on now. I know a little sumpthin! Thougj the jack is a little more forward than the xmembers so I'll move it 6 inches back and try it that way.
#30
Dang it. I did exactly what I was trying to avoid. (No I didn;t strip the bolts). I split my finger open even under the compression tape. So I guess I'll be waiting for troy to get home. I just can't grip the screwdriver hard enough with my right hand and not reopen my wound.
I think it is time to get some superglue and glue my finger shut.
#31
Well guys Magic troy clued me into the nuts on the tip (Hey those Allen bolts never went into any nuts! )
Got the skid off. Um, oil pan is gonna be hard to get to. If I am looking at it right the best way is to take the front xmember off, and or the diff. God please NO! I mean I could get at the very edge of the oil pan but then I'm up into some belts! (In front of the tie rod where the steering stabilizer is... as I assume that would be the easiest to take off. Otherwise I only have a lip of the pan in front of the stabilizer next to the belts.)
I hate all you with anything other than a 2nd gen 4runner. I mean could it be any more of a PITA? (IFS remember)
#33
You asking me or the teeming masses of intelligence on YT?
Yeah I can get to the bell housing. If THAT is the case I didn't have to take the skid off... and my finger is pissed!
#34
I wouldn't, it would take a lot more force to lift the engine from there and it would really suck to put a crack in the bell. Don't you have an engine hoist?
#36
Easy to test, bottle or floor jack and a block of wood is all you need. Lift up under the oil pan and watch the engine and frame move as you do. If a broken mount, you'll see the frame stop lifting at some point but the engine keep rising. Should be able to see one mount separate if it is torn, since it is usually the rubber inside the two halves the rips free:
- http://www.4crawler.com/4x4/CheapTri...torMount.shtml
EDIT: that diff won't be that hard to remove as long as you remove the brace in the front with the four bolts. ZUK has a write up on his site, follow that & it's easy cheesy - try to take the short cut of not removing the brace in the front w/ the 4 bolts holding it on (that the diff front mounting bolts to) & it's a bonifide nightmare.....ask me how I know.
#37
Last weekend we finally got it together after replacing the transmission (and spending another full day on the stipud pilot bearing).... So to have this still going on is getting old! *grrrr*
Yes we do but the hydrolic hoist hasn't been working properly...
#38
Yeah, yeah, we know... Cuz we've removed it like 3 times in the past 6 weeks trying to diagnose locker issues. I guess Troy and I are trying to get out of any work in doing this because seriously we are so ready to sacrifice a virgin to his truck!
#39
