Help 95 4runner auto v6 with 33's cant accelerate over 65mph
I put 32's on a while ago and it seems like 80 is my max on flat ground. I have no tach so idk my rpms. Ima be putting in an sr5 cluster today so thatsa gonna change.
im running 4.88s and 285 75 16s ( 33s) i like the set up nice cruising rpms but still have plenty in reserve.
your problem
look under the dash at the back of your gas pedal ill bet that between that end and the accelorator cable end at the throttlebody you have tooooooo much slack in the cable.
I DID. fixed all me "poor acceloraction problems"
there is a rubber boot on the backside of the gas pedal that broke on mine and would give the pedal too much slack . i removed it and pulled the line tight at the trottlebody.
as for the 488 gear code, it is g144
your problem
Unless I'm mistaken 4.88's should be g144
g214 = 6.667 according to http://www.off-road.com/trucks4x4/ar....jsp?id=274535
#25
thats wierd.. i have 4.11's with 33x12.5's and a manny tranny and i can go 95?
is that wierd? my speedo is only off by 5 but its dead accurate until over 60 .. my truck is a weird one...
#26
#27
#28
Thanks swaycleveland !!
I checked out that cable and sure enough I had between a 1/2 inch and 3/4 inch of slack in that cable before my pedal even pulled it tight. I put a spacer in to take up the slack and now I can chirp my 33's on take off.
#29
#30
lol, my PU on 31's, stock gears, and the 22re before the rebuild with 290k + miles on it wouldn't take me pass 65
but now? psh... she gets to 80 in the time it use to take to get to 50
