Electrical problem. Please help!
Old 04-07-2009, 06:42 AM
silverbullet830's Avatar
I just bought my first toyota. its a 91 4runner 4wd V6. runs pretty good except for one thing. my parking lights and gauges aren't working. fuses are good, blubs are good, changed the combination switch, i have continuity across the dimmer knob. don't have power at the fuse switch or dimmer. i have the chilton manual but i cannot find a wiring diagram of this circut anywhere. it would be very helpful in finding the problem. what should i do?
edit: I did find a wiring diagram that helped me out a while ago.
Old 04-07-2009, 10:28 AM
Update
so right after i posted this thread i figured out that my truck IS supposed to have a taillight relay and it wasn't there. replaced it and they still don't work. i re tested everything. have power at the comb. switch now and the relay is clicking on and off. have power at the fuse and the fuse is good. i checked the glove box switch plug and it does not have power but the power wire has continuity to the body. should i be looking for a damaged harness under the dash? i really didn't want to take the whole dash off but its looking like i probably have to. would the glove box power wire having continuity like that mean a ground short? its not popping any fuses so i'm not sure what to think.
Old 04-07-2009, 02:15 PM
have the dash out checking things out. no visible damage to the harness. still can't find anything helpful though.
Old 04-08-2009, 02:01 PM
well. i guess its a bad wire. don't think its a bad component. probably a cut wire or a screw through the power wire or something.
Old 04-08-2009, 07:54 PM
found it! finally! just gotta put a new plug an a little bit o wire to the license plate. wish i'd found it sooner but it coulda been worse.
Old 04-08-2009, 08:22 PM
RMA
RMA's Avatar
so it was the liscence plate light.
Old 04-08-2009, 09:08 PM
desert-rat660's Avatar
hmm, i dont see how the license plate light was affecting all that if the fuse wasnt blowing. But if its fixed good job to ya
Old 04-11-2009, 02:57 AM
the fuse did blow after i put the relay in. i guess the PO removed it to keep the fuse from blowin. i don't know wtf was goin on but its working now. now i just gotta fix the p/s leak and figure out why don't have near the power i should. think my timing belt might be a tooth off. gonna check that this week.
shooter86314
01-07-2016 07:05 AM
Boomer8404
09-24-2015 01:12 PM
xzen73x
09-14-2015 03:00 AM
EatChipsNow
09-09-2015 01:25 AM
some drunk guy
09-04-2015 11:55 PM
Quick Reply: Electrical problem. Please help!
