custom front bumper 90 4runner sr5 v6 3.0
i wish i had the tools and garage to fab one up but i dont. i settled on the warn rockcrawler though, i like em alot. and i found one almost new for 400 bucks. pretty sweet ill post pics after i get it mounted if anyones interested. thanks guys...
Last edited by waskillywabbit; 02-26-2009 at 01:03 PM. Reason: Rule violations removed.
#26
#27
the warn rockcrawler is a solid steel bumper, i think it may even have some zinc in the powder coat as well. i know when i called on it i was told it weighs 75 lbs more than the stock bumper. its a heavy duty one for sure.
Last edited by waskillywabbit; 02-26-2009 at 01:02 PM. Reason: Rules violation removed.
#29
ROCK CRAWLER FRONT BUMPER FOR THE TOYOTA PICKUP
Here's a bumper that replaces the factory bumper with function and style. Take a look at the sloped vertical surfaces. They're tapered and welded; designed to keep maximum approach angles clear and not act like a plow in deep snow or mud. The sides of the bumper continue around to the flare so they match the style-line and protect the body. Welded eyelets are ready for D-shackles and the winch mounting system is integrated and pull-tested for winches up to 9500-pound capacity. Made from 3/16" and 1/4" steel and black powder coated. The Grille Guard Tube is a bolt on design (tube sold separately).
Note: Not rated for tow bar use
PN 68450 For '89-95 Toyota pickup (excludes Tacoma) (For winches up to 9500-pound capacity, except PowerPlant & M8274-50)
PN 68451 Grille Guard Tube for 68450 (sold separately)
#31
Location: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
I couldnt have agreed more, like a Higgin's boat for example?
#32
icentropy
09-10-2015 05:03 AM
