Coolant in all cylinders, HG looks ok
Old 10-04-2013, 12:10 PM
BeerRunner's Avatar
I think I will work on pulling the engine this weekend and then rebuild it. What is the estimated cost of rebuilding the engine including machine work? I imagine I would want to have the block and head surfaced and the walls bored. Im thinking about buying another working engine to throw in while I rebuild this one.
@Yotasnap I will look into those theorys after work today. The cylinder walls are glossy but i cant feel any ridges with my nail. the bolt was in place and did not seem to tight. but yes the block has oil all over it.
@stock88 Engnbldr is just a couple hours away from me Ill definatly check them out for parts.
Old 10-04-2013, 12:14 PM
BeerRunner's Avatar
@slowey Should I just buy some grade 10 bolts that will fit the block. I feel Like using the bolts that hold in the head is a bad idea.
Old 10-04-2013, 01:27 PM
j2the-e's Avatar
Engines not that heavy. Any old bolts will work. I wouldn't hesitate to use the head bolts, but better safe than sorry if you can easily find the right size
Old 10-04-2013, 01:28 PM
j2the-e's Avatar
Please do some searches regarding oil consumption on fresh rebuilt 22re prior to making your choice of engine internals.
Old 10-04-2013, 07:22 PM
  #25
BeerRunner's Avatar
Will do JE I was planning on getting it all from engnbldr tho. I have heard they're good.
Blamalam
03-12-2022 07:34 AM
Corvoid
09-04-2015 11:55 AM
raptor510
08-19-2015 02:15 PM
Dakotaneu
07-27-2015 12:03 AM
Quick Reply: Coolant in all cylinders, HG looks ok
