Clutch replacement
Old 04-30-2014, 05:24 AM
Nathanzander123's Avatar
Clutch replacement
Hi, I'm wondering what parts I will need to get to put a new clutch in my 95 4runner 3.0. it's not completely out yet but it is sliping more and more and how hard it will be?
Old 04-30-2014, 05:30 AM
Gizler00's Avatar
You are going to want to buy a Clutch Kit. There are a ton of options out there for replacements. I have had good luck with the Aisin ones. Thats what I put back in mine last fall.
But make sure you get a kit that has a new pilot bearing, throwout/release bearing, and an alignment tool with the clutch.
Also, you are going to want to get your current flywheel machined before you install a new clutch on it. Some people replace the flywheel if they have the money. But you can typically get them machined for around 25-40$ depending on where you go.
It is not really that difficult of a job providing you have all the right tools. especially a floor jack if you are working on the ground.
The hardest part for most, it accessing the top two bellhousing bolts. With that I usually remove the tranny crossmember and let the engine/trans hang down to give me more room to access the top bolts.
Aside from that, you will have more trouble getting the starter out than the clutch. HAHA
Old 04-30-2014, 05:40 AM
JasonYota's Avatar
All of this^^
Also you could replace the slave cylinder and possibly the clutch master cylinder while your at it.
Old 04-30-2014, 05:54 AM
Gizler00's Avatar
Originally Posted by JasonYota
All of this^^
Good call on the slave and master Jason. Slipped my mind. Heading to get more coffee to wake it up.
Old 04-30-2014, 08:16 AM
Clutch replacement
Did you order your clutch online if so what website did you use
Old 04-30-2014, 08:23 AM
Gizler00's Avatar
Yes I purchased it from online, but I cannot remember where I bought it from. I can take some time to look later on.
Old 04-30-2014, 12:19 PM
thefishguy77's Avatar
I ordered my clutch from marlin crawler 22reBTW. If they have them in stock I don't think you can go wrong for the price. Worth a call to see what they have.
Old 04-30-2014, 05:34 PM
jreb10's Avatar
You may want to consider replacing the rear main seal when you do the clutch. It would be a shame to have to go back in there again just to get to it if it starts to leak.
Old 04-30-2014, 05:50 PM
JasonYota's Avatar
I was going to say this earlier and got caught up with work.
Even if it's not leaking, change it. The last motor I swapped I didn't because it wasn't leaking and money was tight, and guess what, it started leaking.
Old 05-01-2014, 05:26 AM
Well as far as I know it is all stock with 240k on it and I am thinking about buying a gasket kit to would it be worth it?
Old 05-01-2014, 05:59 AM
Staff
Terrys87's Avatar
I got my Aisin clutch kit from Rockauto. It will have everything you need for the clutch job itself. You will need to purchase the other things seperately.
Old 05-01-2014, 07:10 AM
JasonYota's Avatar
Which gasket set are you talking about?
Old 05-01-2014, 04:09 PM
Probably just the rear main seal.
Old 05-18-2014, 05:31 PM
redsr5's Avatar
Make the job ALOT easier by renting a transmission jack. Money well spent. Use a toyota rear, pricey but no comparison.
Old 05-22-2014, 05:58 AM
Smaay's Avatar
when It comes the the RMS or FMS, I only get OEM seals. Felspar and NPR seals have leaked on me. these are not jobs you want to do more than once.
smthwsn357
12-04-2023 02:08 AM
the1998sr5
15
07-14-2020 08:35 PM
mskalmus
05-28-2017 07:51 AM
09-04-2015 09:27 AM
Kalihi,HI
07-09-2015 04:29 PM
Quick Reply: Clutch replacement
