Bumper nuts & bolts
Bumper nuts & bolts
I recently bought a 1993 SR5 xtd cab pickup 4wd 3.0l without a rear bumper, I ordered a new bumper but I dont know what size nuts & bolts i"ll need to get, does anybody know?
Does that one not have studs welded on it? Do you have it yet to look at? I can't remember how the 2nd gen bumpers are mounted. If I knew what shape holes it has or if it has studs, I can tell you.
I'm having a problem putting up a pic. , but there's 2 brackets that stick out about 6-8 inches that have 2 holes in each bracket 7 are about 41 1/2 inches apart, ...if that helps
I would bet they were M8-1.25, long enough to attach the thing. If you have holes that match under your truck, just go buy you some quality, high strength bolts, nuts, washers and lock washers as big as will fit. Buy grade 8 or 9.9. Don't overthink it and have fun.
Check out a spray can product called Zero Rust. I used it on a project this weekend and have been impressed so far. You don't even have to grind. Time will tell how it works but I saw some metal that some guys were testing it on after a couple months of being left in a muddy spot behind their building. I couldn't get it to peal or come off after beating on it. $11 a can. Got it at Bumper to Bumper.
