Bed mat or liner that will not scratch paint?
Old 05-30-2010, 06:14 PM
1989ToyotaTruck's Avatar
I'm putting the finishing touches on the restoration of my '89 Pickup which I've had, well, since 1989!
I'd like to put some kind of protector in the bed (either a mat or liner) but want something that won't scratch the new paint. Not going to be doing any heavy hauling or anything, but I need something for the occasional grocery run etc.
Any suggestions?
Thanks!
Old 05-30-2010, 06:26 PM
streetlancer's Avatar
Rhino-liner?
Plastic bed-liners?
Old 05-30-2010, 07:54 PM
Jay351's Avatar
I got a factory mat out of a tacoma. Best $40 ive ever spent
Old 05-30-2010, 08:27 PM
JollyGreen's Avatar
The rubber mats work great.
Old 05-30-2010, 09:34 PM
Jay351's Avatar
They do! They work even better if you got a spray in liner
Old 05-30-2010, 10:38 PM
kenbo53's Avatar
ive never seen a drop in plastic liner that didnt scratch the paint underneath it. They get dirt and what not trapped in there and itll eventually wear through the paint unless you take it out and clean everything all the time. id just go with a rubber mat if your not going to be hauling much, its alot easier on the paint and alot easier to take out and clean.
Old 05-30-2010, 10:41 PM
Lysmachia's Avatar
X2... spray on liner is nice but spendy and it DOES fade, even the best UV protected stuff. Sounds like a Rubber mat is the way to go for you!
Old 06-01-2010, 01:02 PM
highonpottery's Avatar
rubber horse mat would be my choice over the stock rubber mats since they're heavier and would add a good amt of weight in the bed for wet weather. btw, i've got the factory plastic bedliner and took it off last season to hose out all the compost that fell through the tie-down access holes - my paint still looks pretty good and there isn't much wear in the paint at all. most noticeable spots are on the high points of the corrugated bed and that's it. you'd think there would be wear along the bedrail, but not on mine. you could always install a plastic bed liner with some sort of material between the two to save the paint, like that pad that goes under Pergo/laminate flooring.
Old 06-02-2010, 01:19 PM
Originally Posted by highonpottery
rubber horse mat would be my choice over the stock rubber mats since they're heavier and would add a good amt of weight in the bed for wet weather....
Thanks--would never have thought to look at a stall mat, but just looking online I can already see a wide variety of interesting styles to chose from.
Thanks!
Old 06-03-2010, 07:13 AM
yep. got that idea once from a friend who lived up in Oregon. said they used those in the back of pickups to add some weight as opposed to sandbags and it would protect your bed at the same time since they're so friggin' heavy duty.
A2theK
09-30-2016 12:50 PM
rap2me
08-11-2015 05:03 PM
jjrbus
08-10-2015 01:09 PM
58rennur4
08-04-2015 08:49 AM
toyota32
07-06-2015 05:42 PM
Quick Reply: Bed mat or liner that will not scratch paint?
