Ball joint spacer = rough ride??
Old 02-12-2017, 05:04 PM
fountain's Avatar
I know these trucks don't ride good from the start, but after I did the b.j. lift, mine is almost unbearable. I'm also running boggers, and I know that's not helping any either. I changed shocks to doestech to no avail. I don't know if the torsion bars haven't ever been adjusted, but I haven't touched them since owning it. I have considered trying to lower it a tad by backing off on torsion bars, but hate to change alignment.
is there any way to get a decent ride out of the truck with the bj lift on? Every little bump i hit feels like they have a 3" lip on them!
Old 02-13-2017, 05:42 AM
coryc85's Avatar
Can you look at your bumpstops to see if your control arms are hitting the upper or lower one? Maybe you need to adjust your t-bars a bit to give you some up and down travel.
Old 02-13-2017, 06:08 AM
millball's Avatar
What tire pressure are you running??
Old 02-13-2017, 02:25 PM
Co_94_PU's Avatar
All of the above.. and/or get softer springs.
I'm to tired to explain the physics, I will let Google..
​​See this link. ( Like I said tired and lazy today..) you changed the lever arm "moment"
fountain's Avatar
Running roughly 27#
Old 02-13-2017, 02:26 PM
fountain's Avatar
Would trying to lower it via torsion bars do anything?
also, I've seen some running ome torsion bars. What would changing them out do?
Old 02-13-2017, 02:27 PM
millball's Avatar
Originally Posted by fountain
Running roughly 27#
That is a reasonable tire pressure, you'll have to look elseware for your fix.
Old 02-13-2017, 02:56 PM
Co_94_PU's Avatar
Take some of the preload off, by adjusting the ride height lower. (See #4, we posted at the same time so you might not have seen it)
I believe the old man emu torsion bars are heavy-duty, they will have a higher than OEM spring rate. You can use them with a lower preload. They have good support and can tell you specifically how the spring rates compare and if they have other than a HD part.
Old 02-13-2017, 02:59 PM
muddpigg's Avatar
Install a heavier bumper and winch.
Old 02-13-2017, 05:55 PM
fountain's Avatar
^ that actually may be an option down the road. I do want a winch/bumper
