Auto to Manual hub swap
Old 01-25-2012, 04:42 PM
t3chth1rt33n's Avatar
So, thanks to WabFab, I was able to find an article on 4x4wire.com about switching from Auto (where you have to reverse in order to unlock your hubs) to manual hubs. But, that article mentions using Warn hubs, not Aisin. Is there a difference? Also, I found a list of toyota part numbers on the internet, but its 5 different parts and that info does not co-incide with the info that was provided on the 4x4wire website. So does anybody have experience with this and have correct part numbers?
I'm sure that the WabFab conversion kit is a good deal, however I work for a Dealership company that owns a toyota dealership where I can get parts at near cost. So, I rather get them the same day for cheaper.
Old 01-25-2012, 05:03 PM
waskillywabbit's Avatar
It tells exactly what you need to get in the 4x4wire article and tells you what to remove and what to add. I just looked at it.
:wabbit2:
Old 01-25-2012, 06:41 PM
Well I had one of the Toyota parts guys email me a diagram of the manual hubs, and Im having trouble distinguishing the "lock washer" from the "flat washer". Do you have part numbers?
Old 01-25-2012, 08:12 PM
cncrestoration's Avatar
i just switched mine and they are really hard to lock in? any input as to y?
Old 01-25-2012, 08:21 PM
vang_22re's Avatar
Take it apart and clean it. Might have to replace the o-ring or mayb trap dirt?
Old 01-25-2012, 08:23 PM
ok will do in morn n post if helped..ty
Old 01-25-2012, 09:07 PM
vang_22re's Avatar
No problem keep us updated
Old 01-26-2012, 04:46 AM
You need 2 claw washers, 2 star washers and 4 54mm nuts.
It says all of this in the tech article and even has pictures. You are removing the auto clutch crap and replacing it with what Toyota put in there to use manual hubs.
:wabbit2:
Old 01-26-2012, 08:27 AM
ok took back apart and cleaned and put back together according instructions,can turn them now without too much effort..but still hard turn im only 1 able turn the wife and daughter cant they tryed..whats up? any ideas?
Old 02-15-2012, 09:00 PM
Today I did my left side. It really wasn't bad at all but the instructions weren't that helpful. I think I'm going to make a write up or something so that people who get stuck in my situation don't have the same problem. I messed around with the hub for like 25 minutes trying to figure out what "spring" it was telling me to compress to get the torx screws. Anyway. It was a good time.
Old 02-16-2012, 01:16 PM
pholife's Avatar
Look forward to the writeup. thank you in advance.
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
oldirtydirt
02-23-2020 09:30 AM
KBar
07-13-2015 06:01 PM
Steven.m.paulk
07-13-2015 01:40 PM
ItsJustD
07-07-2015 07:49 AM
Quick Reply: Auto to Manual hub swap
