Attention 4cyl timing chain owners
Wow someone from louisville, awesome we ought to meet up sometime and give each other a hand working on something. Since I just got the 2wd truck saturday and me and my buddy are in the process of working on the paint and body on my 4wd, it will be a little bit before I work on the engine.
As for the timing chain, I didn't have time to get the metal guides when I pulled it apart to fix it. My dad and I worked on it and since he is always out of town I only had a days notice that we were going to fix it.
As for the new motor I know I'm going to get a cam probably engnbldr. I got a buddy that is insane with head work so I'm going to go to him and have it ported and polished. There is this machine shop out near national turnpike that my buddy with his monster of a truck takes his stuff to so I might go talk to him about boring it. Thats just an idea I haven't really researched too much yet I just remember seeing something about it on a website somewhere maybe it was roger browns site.
Originally posted by Krash
I'm going to put the metal backed guides so that I don't have to worry about them breaking. I'll either do that or put the double row timing chain kit from lc engineering.
roger browns site.
Talk to you soon, man... hopefully we can hook up and talk mods!
#26
probably you best bet would be to look either in the owners manuals or goto a local autoparts store either ask them at the counter or goto buy a cheap haynes book, you get what you pay for though.
#27
b
Not sure about the motor in the 2001's... if it's a V6, and not an overhead cam, then you'll have to look at a service manual, but chances are, it's a chain. I'm not sure I know of a motor (but I'm sure there probably is one) that uses a belt in a V configuration.
If it's a 4cyl, then most, if not all, of them are overhead cam, so simply pop off the valve cover and look at what drives the cam gear. You'll be able to tell easily enough.
#30
Re: b
#31
Re: Re: b
Originally posted by Shane
The 3VZE is belt driven, I'm not sure about the newer V6s Toyota is using.
That's one wild looking belt arrangement, I'll say that!
#32
Re: Re: Re: b
#33
22re
Dude, could you please post the instructions on the timing chain replacement you did. Did you remove the head and/or oil pan to accomplish the task? If so, is it really necessary?
Thanks AJ
Thanks AJ
#34
Thanks AJ
Thanks AJ
here is a link to a FSM to use as a guide. http://personal.utulsa.edu/~nathan-b.../8timingch.pdf
#35
Originally Posted by PirateFins
No and no answers your questions. You do not need to remove the head or oil pan. There are 2 bolts in the bottom of the chain cover that are removed from under the front of oil pan, and one under the distributer gear, hidden in an oil valley.
Sorry bout the link but this post is about 3 years old. Apologies for bringing it back from the dead but just an explaination for the dead link.
Steezy96yota
07-06-2015 10:00 AM
Suprarossa
07-06-2015 05:21 AM
