Anyone have a write up on 1st gen rotor replacement?
Old 12-30-2012, 03:27 PM
Toyomo's Avatar
I did this years ago on another 4runner and I remember it wasn't exactly easy. I have a manual but it's not helping me much.
Anyone have any links/walkthroughs?
It's for an 87' 4runner for those who are interested.
Old 12-30-2012, 04:09 PM
timothy47129's Avatar
I'm sure someone on here can give you the link to download the factory service manual.i downloaded it but don't have the link were its located
Old 12-30-2012, 04:13 PM
totally a bro
Staff
vital22re's Avatar
you'll need to pull the rotor hub assembly. The rotor is bolted to the hub from the back side. This involves removing the brake calipers/caliper bracket and spindle nut that holds the wheel bearings. May as well as pull the front and rear bearings out and inspect for abnormal wear then clean and repack them. Don't forget to replace the seal on back of the hub.
Old 12-30-2012, 04:14 PM
brianh699's Avatar
I'm assuming you mean brake rotor?
Old 12-31-2012, 02:07 AM
wyoming9's Avatar
Red face
Pretty simple but it does help to Have The 54MM spindle nut socket the hammer and chisel is so messy .
I have never had problems getting the rotors off with a 1/2" air impact I have heard horror stories trying to break the bolts loose by hand.
Have the correct wheel bearing grease and the correct seals .
Do you have a extra vehicle if you need to replace any of the wheel bearings??
If you feel any rough spots or the feel loose or make noise you got lucky and caught that before it failed.
Packing wheel bearings is pretty easy but if you have never done it takes a little time to get it down correct.
Old 12-31-2012, 05:50 AM
waskillywabbit's Avatar
Look at solid axle rebuild threads. Lots of pics and details.
:wabbit2:
06-01-2021 01:51 PM
msane99
07-11-2015 08:08 PM
ItsJustD
07-07-2015 07:49 AM
coryc85
07-06-2015 04:07 AM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: Anyone have a write up on 1st gen rotor replacement?
