Anyone Have the link to Rear window Repair Write Up
ya i know once the window goes down the tailgat will open. how did you get the window down manually i tried prying and pulling the heck out of the sprokets to get them to move but nothing happens
i need a method to help me get the window down manually i also have pulled down on the window with two people
With mine the gear was just stripped on the motor so if I pulled down on the window while someone pushed the button it would go down. But if you can get the gear from the motor separated from the assembly it will release the lifting arms allowing you to lower the window. You just have to get the gear of the motor moved enough to clear the teeth on the other gear.
ya thats what i was thinking but i havent been able to get the motor off yet hopefully tommorow does it matter if those rails are super rusted
it shouldnt matter, mine were really bad and I cleaned them up a little bit but they are still pretty rusty and the window works fine with the new motor. if you cant get the gear separated you could always try pushing enough to spin the motor gear so it goes down. Its been a couple years since ive seen the inside of my tailgate so i cant really remember how everything looks in there.
#26
What do these wires do on my rear tailgate window. Pics Included
I took apart my rear tailgate apart to replace my window motor that all fixed but before i put back on the cover i want to know what these wires did hooked to the bottom right part of my tailgate window
anyways mine are sniped and the one part is all electrical taped together is this toyota factory work or the previous owner fix. but i can understand what the wires do that are attached to my window
heres pics
first you can see the wire that has been snipped
heres a shot of the wires and the electrical tape job to where it hits the window
and heres the shot where the wires meet the window
i still dont have the closest idea why wires would be connected to the window
please help so i finish my rear window job
heres pics
#27
Look at your second picture, it looks like the wires came loose or broke from that taped piece, thats what it looks like to me, but the picture is not real clear.
#30
rear defrost sir your are excately right i think, because my rear defrost currently doesnt work im gonna re attach those wires and see what happens
#31
is there a reason someone would cut the rear defrost becuase it use to be a florida vehicle and there is tint on the windows dont know if those could be reasons
#32
hahahaha i did the exact same thing this morning dude ya its defrost i think they just get brittle and break from going up and down but mine had some wire butt end connecters but ya mine looked snipped too
#33
Ive had tint on rear windows of vehicles that had rear window defrost, and never had a problem with the tint melting or comming off, so im wondering if the wires just broke on there own from the window movement over the years of use ?.
#34
The pictures are a little blurry to me but I agree with myyota as to why it is taped togher, age just made it fall off the tab it's supposed to be affixed to on the window. Tint is not a real good reason to disconnect the rear defrost, all my vechiles have tint (aftermarket or factory) & rear defrosters and they are all wired. Even if they don't all work 100%.
#36
Rear defrost. Super common for the wires to snap there.
I had to fix that, and even with 12 volts of power the rear defrost doesnt work well at all. The switch gets hot after a few mins!!
#39
I have to park outside at work. So I guess I use mine 8-10 tes a month during the cold season. I must say I am way happier having it. More bc everything works, and now I can say everything works. Gosh that sounds good. Everthing works. another 4runner daydream......
06-01-2021 01:51 PM
crashburnoveride
07-10-2015 06:39 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
