Another 22re turbo thread
Old 07-08-2018, 07:50 AM
jaretstuff's Avatar
Cam retaining caps aren’t supposed to be two piece
Old 09-22-2018, 03:00 PM
jaretstuff's Avatar
Old 09-25-2018, 05:28 PM
superex87's Avatar
I know you already bought the factory turbo charge pipe but If I were you I would run a front mount air to air intercooler. With the high stock compression it will be a necessity to prevent knocking. Another option would be an air to water intercooler. Once you get it up and running your going to want to crank up the boost (within reason).
Old 09-25-2018, 05:45 PM
jaretstuff's Avatar
yea I’ve definetly thought about it. This truck is a multi stage affair. I want to get it up and running and monitor my IATs and see what they are looking like and then most likely run an intercooler. I’ve had a couple of ideas possibly doing a setup similar to a WRX
Old 10-07-2018, 09:25 AM
  #25
jaretstuff's Avatar
Old 10-07-2018, 02:01 PM
  #26
87-4runner's Avatar
Make sure you do your best to get those hard to reach oil lines, water lines on the turbo... the exhaust gasket, the header to turbo, and the wastegate down pipe ... all sealed and TIGHT...
get the best gaskets you can... the cheap ones burn out quickly... ask me how i know...
plus i got Allen head bolts for the turbo to exhaust flange, the exhaust to downpipe flange, and the collector... makes it MUCH easier to reach and tighten those hard to get to places... you can cut a d bend thre Allen wrench to exactly what you need to get to them on the truck.... off the truck it ain't so bad, on the truck a whole new ball game....
I just reclocked my turbo as it was too close to the header... got the inlet silicone sleeve hot and blew a hole in it this morning at WOT... lose boost pretty quickly that way... was a long drive home with no boost...
Old 10-07-2018, 02:13 PM
  #27
87-4runner's Avatar
My down pipe with O2 bung
Old 10-07-2018, 02:15 PM
  #28
jaretstuff's Avatar
thanks for the advice man, I appreciate it. I’m making a couple heatshields and will be getting an intercooler in the next couple months
Old 10-07-2018, 02:16 PM
  #29
87-4runner's Avatar
This is the wastegate flange I'm using and it works fine....
Old 10-07-2018, 02:19 PM
  #30
87-4runner's Avatar
Cool... made my heat shield too...
Old 10-07-2018, 02:25 PM
  #31
87-4runner's Avatar
I'm also fixing to cut the freaking tubes off the inlet pipe... going to just run hose from the radiator to the turbo line... and a single hose from the valve cover to the intake tube.. its a pain and makes a mess everytime you take off the inlet pipe which for me has been several times... plus you have to wait for everything to cool off so you don't get scalded... I'm done with that lol
Old 10-07-2018, 03:58 PM
  #32
jaretstuff's Avatar
I’m so glad o got the piping kit, was wayyy easier
Old 10-08-2018, 08:34 AM
  #33
rufflz's Avatar
in for progress
Old 10-08-2018, 08:42 AM
  #34
jaretstuff's Avatar
Originally Posted by rufflz
in for progress
once it is completed I’m going to write a professional write up
Old 10-28-2018, 06:56 PM
  #35
jaretstuff's Avatar
Old 10-28-2018, 08:05 PM
  #36
Co_94_PU's Avatar
Originally Posted by jaretstuff
That looks horrid, you better start all over again..
Old 10-29-2018, 09:50 AM
  #37
jaretstuff's Avatar
for sure, I hate having ugly engine bays
Old 10-30-2018, 04:57 AM
  #38
jaretstuff's Avatar
Megasquirt and IAT sensor have been ordered
Old 11-07-2018, 12:03 PM
  #39
87-4runner's Avatar
I hope your header last longer than mine did... about 100 miles and cracked in two places
I bit the bullet and got this...
Old 02-16-2019, 06:00 PM
  #40
jaretstuff's Avatar
Megasquirt is built and installed
better quality turbo ordered
innovate LC 2 wideband kit and gauge installed
full 2.5 in exhaust from the turbo back with a full size muffler with miter cut tip
Quick Reply: Another 22re turbo thread
