94 PU- Blinker wont stay on
Old 03-31-2006, 10:15 AM
rizzle1024's Avatar
Hi, I recently got my 1994 Toyota Pickup and it seems that something might be wrong with the blinker. So I will click the arm either up or down for which ever direction I am turning, I do this about 100 feet (i have tried at other distances) from the time of my turn. Then when I turn the wheel not even a 1/4 of a turn it just clicks off. I cant seem to get it to stay on unless I hold it down while I turn the wheel. Does anyone know why this may be? Any help would be greatly appricated.
Thanks, Ryan
Old 03-31-2006, 10:24 AM
Jeffires's Avatar
The plastic turn signal cam being worn out can cause the blinker to either switch off, unexpectedly, or remain on after the wheel is straightened and it should return.
Old 03-31-2006, 10:48 AM
rizzle1024's Avatar
Is it reasonably possible for one to replace this?
Old 03-31-2006, 10:53 AM
Jeffires's Avatar
The part should be cheap, and you should be able to do it yourself. The worst part will be pulling the steering wheel (if it's necessary, I've never changed one on a Toyota)
Old 03-31-2006, 10:57 AM
Tacoclimber's Avatar
I have pulled a wheel on a Toy, and it's really not any more difficult that any other vehicle. Getting the center nut off is a little tough, but once you do, both wheels I've pulled came off by hand... Granted I live in AZ, which may make it easier...
kawazx636
10-06-2021 03:03 PM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
creecher10
09-30-2015 03:27 PM
Scotttekoch
09-28-2015 10:30 PM
Quick Reply: 94 PU- Blinker wont stay on
