4x4 doesnt work
Old 01-29-2009, 07:59 PM
dirtrider38's Avatar
4x4 doesnt work
hey one day i locked my hubs and when i started to drive the front end started to hop then stopped and now my four wheel drive doesnt work. any ideas as to what is wrong?
Old 01-29-2009, 08:46 PM
my-4x4's Avatar
any more details about your vehicle and the issue (did it work before? did u just purchase the truck? etc)
Old 01-30-2009, 03:18 AM
yes it worked before now after the hopping it hasnt work
Old 01-30-2009, 03:19 AM
my bad i forgot to mention 88 toyota pick up with the 22re
Old 01-30-2009, 04:29 PM
no one?
Old 01-30-2009, 04:55 PM
toyminator2000's Avatar
Its Broke.
Old 01-30-2009, 04:59 PM
yes i need some help
Old 01-30-2009, 05:03 PM
Are both hubs locked in?
Look at the axle shafts to see if they are messed up.
Check to make sure the front driveshaft is turning.
IF its turning then you
Old 01-31-2009, 08:11 PM
superpeanutman's Avatar
take your head and put it at the front of the vehicle, look at the two peices of pipe comeing from the two front wheels going into the middle. if they are hanging and draging then that means bad. if they are tight and looking good. then look at your front drive shaft. it should not be dragging on the ground. if its not dragging on the ground. then you need a new muffler bearing
mskalmus
05-28-2017 07:51 AM
MTLroadierunner
07-15-2015 12:58 PM
MTLroadierunner
07-06-2015 12:17 PM
Steezy96yota
07-06-2015 10:00 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 4x4 doesnt work
