3VZE - Spring or hydraulic tensioner?
Old 06-14-2012, 01:28 PM
adamthedroog's Avatar
I'm about to get a timing belt kit but I don't know which to get. How do I tell what I need?
Old 06-14-2012, 01:58 PM
TNRabbit's Avatar
What year is your engine? The belt is the same for either one...
Old 06-14-2012, 02:01 PM
93toyrunner2's Avatar
Early 90's had a spring, and later 93-95's have the hydraulic tensioner. Be sure, pull your timing cover off and look!
Old 06-14-2012, 02:17 PM
Mine's a 1990 so I guess it's a safe bet that it's a spring tensioner then.
Old 06-14-2012, 02:24 PM
phildelfino's Avatar
here's what mine looks like. if you can see it, it is a spring tensioner.
Old 06-14-2012, 02:29 PM
Spring / Hydraulic
If you are not the original owner, don't assume anything. Do you know for sure that the motor in your truck is original? Not every seller is honest and tells you about all the things they changed.
Old 06-14-2012, 07:25 PM
The people before us treated it pretty awfully so I doubt they changed anything besides the belt. (I was even surprised they did that). I think I'll just pop off the cover and look to be sure. Is there any benefit to having a hydraulic tensioner and if there is could I put one on somehow?
Sean McAuley
9
11-08-2015 12:26 PM
justdifferentials
Just Differentials
09-08-2015 03:15 PM
justdifferentials
09-08-2015 03:13 PM
Flossy
08-05-2015 05:14 PM
Quick Reply: 3VZE - Spring or hydraulic tensioner?
