36/15.5 tires on 4-5inch lift
Zero issues other than what I mentioned above. It barely rubs the upper control arm but that is if you are flexing the sidewall or lowering the tie pressure. The original owner of the truck used 1/4" spacers in the front so it would not rub at all. It is safe and I have done it before with thousands of miles on the street.
James
James
Zero issues other than what I mentioned above. It barely rubs the outer tie rod end but that is if you are flexing the sidewall or lowering the tie pressure. The original owner of the truck used 1/4" spacers in the front so it would not rub at all. It is safe and I have done it before with thousands of miles on the street.
James
James
The main issues with wheel spacers are:
a) pushing the rim out from the hub, particularly on the steering axles, puts strain on wheel bearings.
b) pushing the rim outward on the steering axles moves the contact patch outward from the 'imaginary' line drawn through the upper and lower ball joints (steering axis inclination). When that happens, it makes the front wheels' steering more susceptible to bumps, potholes, etc. in the road.
#29
James
James
James
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
nickbeauregard
12
08-07-2015 06:04 AM
Luvmeye22re
08-04-2015 03:53 PM
coffey50
07-28-2015 10:55 AM
