33x10.5's on 15x8?
Old 04-07-2006, 12:16 PM
-MaTTi-'s Avatar
Another vote for 33x10.50R15s. I like them. I have same kind of tire set (BFG AT) in my garage waiting when the old ones are worn out.
Old 04-08-2006, 07:07 AM
Cph Sonshyne's Avatar
They look fantastic..just what im after, a big thank u goes out to curly c for your time and effort..
Sonshyne
Old 04-08-2006, 05:14 PM
curly_c's Avatar
haha so this thread got compleatly hijacked.... no problem for the pics
Old 04-09-2006, 09:35 PM
Keggo's Avatar
Not really... it's still concerning 33x10.5 tires... I wouldn't suggest having the rim size near the same width as the tire. Because if you think about it, if you put a 33x10.5 on a 15x10 rim; the tire is only 10.5 inches at the widest point of the sidewalls...
Old 04-09-2006, 09:59 PM
  #25
Bobakazi's Avatar
Originally Posted by Keggo
I'm getting ready to buy new tires... I currently run 33x12.5. I really want something lighter with less rotating mass, but still want the clearance. I'm going to get Dunlop Radial Rover all terrain tires in 33x10.5. How do you guys think having 15x8's with a 10.5 wide tire would be? I'm just worried if I air down my tires while wheeling my bead would break loose. Any comments/suggestions? Thanks!
Back to the original. Running a tire a couple inches wider than the rim is what I like best. I run 12.50s on 15x10s and have never broke a bead, even down to 5 lbs on the sand, and 12 on trails. BTW, I am sure you will notice that is 2.5" +/- difference, which is what you would have. (+/- depending on the tires).
Old 04-10-2006, 01:22 AM
  #26
netgodsrdn2's Avatar
Don't mean to highjack but it is related...
Can anyone offer any feedback on how 33x10.5 would be with a 22re automatic transmission and 4.88 gears? I'm not expecting to win any drag races, but would still like it to move.
Old 04-10-2006, 09:42 AM
  #27
PO2SIMS's Avatar
w/ 4.88's u should be fine.
Old 04-10-2006, 12:14 PM
  #28
tc
tc's Avatar
I really like 4.88's with 33x10.5 with manual tranny. Given how tall the overdrive is in the automatic, I would go 5.29 if you can. You will have a hard time holding overdrive on anything remotely up hill.
Old 04-10-2006, 12:39 PM
  #29
hmm. I got a screaming deal on a pair of factory 4.88 thirds that already had lockers. I haven't installed them yet. Maybe I could just sell them and get 5.29's... Thanks for the input.
Old 04-10-2006, 12:50 PM
  #30
tc
tc's Avatar
4.88's would be OK - I just think you would be happier with 5.29's with the auto tranny, especially at altitude with the 22RE - I have 3VZE, so a little more power.
If it was such a screaming deal, just get 5.29's and master install kits, and sell the 4.88's and you'll still have gotten a good deal! Plus, you can take the thirds to have the gears setup and save a lot of money on install (should be around $200/axle for install).
Which lockers? Both front and rear?
Old 04-10-2006, 01:00 PM
  #31
They are factory 4.88's. The only replacement on that rear 3rd as far as I understand it is another set of toyota factory 4.88's. If I remember correctly the rear is a Detroit Locker and the front is a Lock-Right (I'm at work right now but I think thats right).
Old 04-10-2006, 01:09 PM
  #32
tc
tc's Avatar
Oh yeah .... forgot about that - I had 4.56 and went to aftermarket 4.88...
Now the rear, you might be OK - the Detroit replaces the entire carrier. I wonder if aftermarket gears would fit on it...
Front with a lock-rite you have the factory carrier though. I might be able to help with that - I'll send you a PM.
theduck21
09-10-2015 07:01 PM
Yotoder865
07-09-2015 07:51 PM
4x4taco
7
04-25-2004 05:10 PM
4x4taco
22
04-24-2004 12:23 PM
Fink
23
10-31-2003 12:36 PM
Quick Reply: 33x10.5's on 15x8?
